HP Elitebook 850 G6 BIOS UNLOCK
you must have a hot air and programmer
you must desolder the bios chip from your motherboard , read it wit programmer and upload THE fiLe here
THAN SOMEONE WILL HELP YOULeave a comment:
Please help me unlock bios password HP ELITEBOOK 850 G6
S/N: 5CG93737MB
ThanksLeave a comment:
Please unlock my HP EliteBook 850 G6.
laptop details
HP EliteBook 850 G6
ProdiD - 4YD63AV
SN# 5CG012F48S
Thank You!
Hello guys. Sorry for the stupid question, but can the Elitebook 850 G6 be unlocked without removing the chip (using a clip in place like on the X1 Carbon for example) or the chip needs to come off?
Thank you!Leave a comment:
hereAttached FilesLeave a comment:
hello!) please unlock my bios 850 g6 my s\n: 5CG944406BAttached FilesLeave a comment:
Serial : 2TK9430D4QAttached FilesLeave a comment:
hp 850 g6 bios pw
6050a3022501-mb-a01[a1]
28K9430D4Q
any can give unlock file plsAttached FilesLeave a comment:
Channel: BIOS Requests ONLY!
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by Loli PopuHello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
by druxHi,
I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
These models have AMI/Aptio BIOS.
Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...-
11-03-2024, 01:18 AM -
by clrscrplease help me unlock bios password hp elitebook 835 G11
S/N: 5CG50434RD
thanks!...-
- Loading...
