Need monster tulpar T5 V17.1 Bios
  • bilen
    • Aug 2014
    • 637
    • istanbul
    SR40B changed. but no image. 0.90 amp stays
    Motherboard code : GJ5CNXX MB REV 1.0
    is there a new clean me bios for this model?
    orginal dump :
    • 21679
    Re: Need monster tulpar T5 V17.1 Bios
    Copy Flash image toolkit (Attached) ,your bios backup and the new ME firmware (Attached) to a new folder on your desktop.
    Start FIT, drag your bios onto the FIT program window,click on "Build" then "Build settings",change "Generate Intermediate Files" to No (you don`t even have to do that but its the recommended setting) .
    There are no other settings to change,there is no special security setting in your bios. Just click on "File" then "Save-As" ,it is already titled "Untitled.xml" ,save it.Close FIT .
    Copy the ME firmware that ive renamed to "ME Sub Partition.bin" into the "Decomp" folder inside the Flash Image Tool folder, overwriting the old ME Sub Partition.bin file.
    Start FIT again,click "File" then "Open" ,select the "Untitled.xml" file ,then click on "Build" then "Build Image" . The file is built and saved as "outimage.bin" ,open it with MEAnalyzer it will say configured.
    MEAnalyzer - https://github.com/platomav/MEAnalyz...253.0_r262.rar
    • bilen
      • Aug 2014
      • 637
      • istanbul
      no new firmware?
        • 21679
        Originally posted by bilen
        no new firmware?
        the new firmware is attached at post #2 . It was renamed to "ME Sub Partition.bin" .I can`t write any easier instructions than what ive already posted, the whole process should take around 1 minute.
        • bilen
          • Aug 2014
          • 637
          • istanbul
          why this error?
            • 21679
            why this error?
            You`ve done something wrong. Watch this video,starting from 2 minutes - https://www.badcaps.net/forum/attach...8&d=1599664171 .The method is exactly the same,except the firmware in the video is named ME Region.bin ,and yours is named ME Sub Partition.bin
            • bilen
              • Aug 2014
              • 637
              • istanbul
              haklısın. başka bir bilgisayarda yaptım
              there is a problem with my system...
              thank you...
                • 21679
                After you have made a mistake with FIT its best to delete the Flash Image Tool folder and use another untouched Flash Image tool, or go into the FIT folder and delete the fit.log,outimage.map and any xml files ,leaving only fit.exe and vsccommn.bin ,then start over again.
                Atached is the bios with clean firmware
                • bilen
                  • Aug 2014
                  • 637
                  • istanbul
                  thank you brother. i solved the problem and got it fixed.
                  tested working dump :
                    • 21679
                    Your file and mine are identical, nice job
                    • yucel-yucel
                      • Dec 2017
                      • 145
                      • türkey
                      As a result of the sr40b change, my bios displays lagging.
                      I tried to clear my bios according to the instructions here but I couldn't run the program. I would greatly appreciate it if you could help me clear my bios.
                        • 21679
                        The bios at posts 8 and 9 both have clean ME firmware,you can use either of them. If you want to use the original win key you can copy it from your backup to the new one using a hex editor with the off-sets in the picture. HxD has a tukish language version
                        https://mh-nexus.de/en/downloads.php?product=HxD20
                        • yucel-yucel
                          • Dec 2017
                          • 145
                          • türkey
                          thankyou very much
                            • 21679
                            thankyou very much
                            You`re welcome
                            • burak.yrms
                              • Apr 2021
                              • 3
                              • türkiye
                              do you have thıs model ec bios
                              • yucel-yucel
                                Monster Tulpar V20.3 Clean Me Bios
                                by yucel-yucel
                                I need Monster Tulpar V20.3 Clean Me Bios.
                                The srkma chip was replaced, I tried to do a clean me but I didn't get any results, it opens late.
                                Can you do a clean me for my original bios, thank you.
                                GM5TG0O222100999
                                MNS220330000307​...
                                04-21-2025, 07:12 AM
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                              • yucel-yucel
                                Monster Tulpar T7 V20.2 Bios
                                by yucel-yucel
                                Since the Monster Tulpar T7 V20.2 model device did not trigger, I replaced the SR40 south chip. However, it is currently stuck at 0.2 ampere current. I tried different BIOS models, got the trigger but no image. If anyone has the original clean bios of this device, I would appreciate it if you could share it. My original faulty bios is attached.
                                MB PCB - GK7MR0R_V1.1 10L
                                P/N - MBPGK7MR0A-RM11
                                GK7MR0R2202808153
                                MNS200715000418...
                                11-24-2023, 05:54 AM
                              • Vesko356
                                by Vesko356
                                08-11-2023, 03:27 AM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
