Re: thinkpad a485 bios password
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..
My wife is after surgery, so i didn't tried file yet, but for sure will try today. As you mentioned, faster or later someone will ask "how did you do it".
I asked because lot of people write "here is your patched file, and why tf you don't use autopatcher" even didn't knowing it is not working out in this modelLast edited by rbvndonh; 04-29-2023, 09:04 AM.
Originally posted by rbvndonh View PostMy wife is after surgery, so i didn't tried file yet, but for sure will try today. As you mentioned, faster or later someone will ask "how did you do it".
I hope everything went well!
And I hope when you saw the doctor after the surgery you've said "Thank you!" instead of "How did you do it?". I guess you know what I mean.
volinakis - you are my hero. It worked out. This will work also for other A485 (i see people already downloaded it) or it need to be prepared exactly for each mobo? I partially see in HEX where changes was done, but i'm for now too weak to understand how it works. Just see this file vs autopatcher is far different. To be honest i have 1 more somwhere hidden in the box with ryzen 5 and other (just working mobo with pass) with ryzen 3..
Vesko - thank you. She walk as a grandma now and have not funny facial expression (as she had something in her pants, if you know what i mean ) but will be OK.
Just need to run after her like: pick this up, pick that up...
I found the box with "do it in future" laptops. Here is another A485 Ryzen5 file if you are open to help more.
I am also open to donate forum for each help or paypal if you're not happy to have too much free work
Like i promissed i did few days ago 5USD donation as i sometimes spam with dumpsAttached Files
So go ahead do it now before it's too late.
Your patched dump is below. Good luck:Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by rbvndonh View PostThank you.
Of course file worked out Thank you for that. Donation done.
Here is last file with Ryzen 3.
I would like to take the opportunity to invite again all members to consider a donation.
All members should be aware that there is a real possibility this section of the forum to be closed because the volume of uploaded files is increasing every day, the number of members in it also, but only a few people donate.
Every day we delete files from the old threads in an attempt to save the situation, but this will not solve the matter. I urge everyone to be more active, everyone can afford a small donation, let more people get involved, only this will save us from the possibility of running out of space to store data on the server!
#3 patched:Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
3rd machine also return to life. Thank you
I see it is all about EVSA store, however i have only IDA free, so reverse engineering of what i see will take muuuch time for me or learning how work Lenovo translate service and then which GUID shall to change.
One day wife will be better and i will be boring..
Another 5USD donated from me. Just forgot this time to sign that was me
Today I have Lenovo A485 with Ryzen5 2500U. All Intels I am doing at home with patcher, but there is none for Ryzen. Can You help me?
Chip is W25Q128FW_1.8V.
Dump in file.Attached FilesLast edited by zerbatin; 08-11-2023, 08:25 AM.
Dump in file.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by Kaar3l View PostHello!
I bought dead A485. Removed USB-C port that was shorted and now it has bios password.
I did take off the bios chip and read it.
Could anyone modify so I could remove password?
And next time provide serial - as rules requires.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by volinakis View Posttry and follow steps described in autopatcher
Thank you!
I did the mod with autopatcher. Then soldered chip back. Followed the tutorial, it froze on going to bios screen. Soldered chip off and back to programmer. Programmed the previous unmodified dump and it then got to bios. (Y)
Did also 10$ donation.
The laptop serial number
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
