can someone fix this please fan at full speed no display attached is original dump
samsung np500p4c need to fix bios
Tags: None
Re: samsung np500p4c need to fix bios
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by KjellAfter installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...08-01-2025, 09:15 AM -
by joshAUHi all.
I'm looking for a BIOS file for an Asus N550JK.
I have a Asus R552J, which I believe is identical to the Asus N550JK.
I downloaded the latest BIOS (210) for the R552.
It is named N550JKAS.210.
The BIOS file is however only 6mb in size.
I've read the chip with a CH341A programmer and verified the file.
That file is actually 8mb in size.
I'm wanting to remove the BIOS password from this unit.
It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...-
by kingiiiCan someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
Thank you very much-
by miccodanDevice: Laptop
Brand: Dell
Model: Inspiron 7573 2-in-1
Service Tag:1G8B6P2
Board number: kylo ren 15 16841-1 H7TJX
Symptoms: With original bios the laptop will not post, keyboard and power light flash on/off upon pressing power button and no fans spin. Attempted to use bios found on here and with other bios the laptop powers on and fans run at full speed and stays running but will not post.
original bios is attached. Many thanks in advance!-
- Loading...
