Willem PCB 5.0E Software??
  • samtron786
    • Aug 2016
    • 155
    • germany
    Hello
    I am looking for the program for PCB 5.0E so that I can write the Winbond 25Q128FV chip, can I write the program or not ???
    Thanks very much
  • samtron786
    • Aug 2016
    • 155
    • germany
    Re: Willem PCB 5.0E Software??
    can you also delete read and write with PCB 5.0E Bios chip 1.8 volts??
    • samtron786
      • Aug 2016
      • 155
      • germany
      25q64fwsig 8m 1.8v
      • araxnido
        Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
        by araxnido
        Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
        When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
        06-10-2025, 09:26 PM
      • ChaosLegionnaire
        bug of the month: write caching setting for the hard drive in device manager
        by ChaosLegionnaire
        i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
        so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
        10-06-2019, 01:39 PM
        Copy DMI info easily with Hex editing software and Macro script
        by SMDFlea
        Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
        Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
        02-28-2023, 02:14 PM
      • modtool
        Problems writing MX25L25673G
        by modtool
        Hi to all, I'm facing a problem writing to an MX25L25673G SOIC-16 bios chip (part of an HP EliteOne 1000 G2 27") with a Willem programmer 5.0B (with software PCB98D12c4).
        I know my programmer is old and I've planned to buy a new one but it worked until now with every eeprom I've faced in different devices, this is the first time that is giving me this kind of problem and I need to urgently solve it because I've already changed the fried southbridge and cleaned its ME fw, so I need to finish the last step of the repair.
        This Willem supports some 256Mbit eeprom, I can choose between...
        04-02-2023, 11:56 PM
        by SMDFlea
        Bad...
        09-02-2021, 04:40 PM
