HP TPN-C125 BDL50 LA-D704p Rev 4.0
  • Renzo
    • Oct 2020
    • 21
    • Iran
    HP TPN-C125 BDL50 LA-D704p Rev 4.0 computer has a password on its bios, i have tried some other files that were for the same model, but still the computer isn't running.
    This is the original file, some one can help and clear it
  • peste
    • Dec 2016
    • 12859
    • ROMANIA
    Re: HP TPN-C125 BDL50 LA-D704p Rev 4.0
    try this
    • Renzo
      • Oct 2020
      • 21
      • Iran
      not working , not turning on , no boot up
      • peste
        • Dec 2016
        • 12859
        • ROMANIA
        post the full name and model of the laptop
        • Renzo
          • Oct 2020
          • 21
          • Iran
          Ok
          • zolie
            HP 15-AY023NH BDL50 LA-D702P REV 1.0 bios
            by zolie
            I need help with my bios. The bios will get stuck on startup. Thank you.
            HP 15-AY023NH
            BDL50 LA-D702P REV 1.0...
            06-21-2022, 07:10 AM
          • m041633n
            HP 15-be002tu BDL50 LA-D702P Rev 3.0 Power's On But No Display!
            by m041633n
            Tried Flashing the Bios from HP Website with CH341a Programmer
            (Extracted the BIN File using HP's "Copy BIOS image in order to use it on other devices" option)
            Tried the First One 081EC From the 5 BIN file's (081EC, 081ED, 081EF, 081F2, 081F3) which was extracted and decrypted already with the BIOS Update Utility from HP.
            But still the Same issue
            the Laptop's powering up, the HDD is not spinning nor the hdd led is blinking nor the Caps Lock led is blinking nor the cpu is heating, there is no display! Cleaned the RAM and the RAM Slot with IPA. Tested powering...
            12-31-2023, 04:04 PM
          • eniac22
            HP 250 G5 / BDL50 LA-D704P missing ACOK
            by eniac22
            Hi i have problem with HP 250 G5 / BDL50 LA-D704P no power / no light on charger led, the same problem with charged battery.
            I measured the following voltages with charger and without battery, i believe voltages is correct except ACOK.
            Pin 1 ACN : 19,4V
            Pin 2 ACP : 19,4V
            Pin 3 GMSRC : 19,4V
            Pin 4 ACDRV : 25,2V
            Pin 5 ACOK : 0V
            Pin 6 ACDET : 2,6V
            Pin 7 IOUT : 0V
            Pin 8 SDA : 0V
            Pin 9 SCL : 0V
            Pin 10 ILIM : 0V
            Pin 11 BATDRV : 0V
            Pin 12 SRN : 3,1V
            Pin 13 SRP : 3,1V
            Pin 14 GND : 0V
            01-12-2022, 08:16 AM
          • Renzo
            by Renzo
            HP TPN-C125 BDL50 LA-D704p Rev 4.0Hello my dear, your computer has a password on its bios, i have tried some other files that were for the same model, but still the computer isn't running.
            This is the original file, some one can help and clear it....
            09-23-2021, 05:41 AM
          • regi
            HP 250 G5/BDL50 LA-D704P Rev 4.0 Water damage
            by regi
            Hi
            I have this notebook with liquid damage (see picture).
            After cleaning the marked areas notebook turns on when pressing the power button and the fan spins for about 8 seconds and stops then, but the display does not come on.
            The battery charges when it is attached (LED turns orange), but won´t start from battery.
            When on these coils have:
            PL202 = 16,81v
            PL602 = 1,021v
            PL1206 = 0v
            PL1205 = 0v
            PL1203 = 0v
            PL11 = 1,209v
            PL9 = 3,385v
            PL8 = 5,08v
            I only have...
            09-05-2021, 04:18 AM
