LA-G07DP Rev V0.3
  • jackx
    • May 2020
    • 223
    • casa1
    LA-G07DP Rev V0.3
    i need bios v3
    LA-G07DP Rev V0.3
  • peste
    • 13451
    • ROMANIA
    Re: LA-G07DP Rev V0.3
    Originally posted by jackx
    i need bios v3
    LA-G07DP Rev V0.3
    post the full name and model of the laptop and the backup of the original bios.
    • thxd43
      Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
      by thxd43
      Hello, first of all, excuse me, I am using the translator, English is not my native language.
      I have a Lenovo ideapad 330S - 14IKB laptop.
      The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
      02-23-2023, 08:37 PM
    • miccodan
      Bios for Dell Inspiron 7573, laptop wont post, original bios attached
      by miccodan
      Device: Laptop
      Brand: Dell
      Model: Inspiron 7573 2-in-1
      Service Tag:1G8B6P2
      Board number: kylo ren 15 16841-1 H7TJX
      Symptoms: With original bios the laptop will not post, keyboard and power light flash on/off upon pressing power button and no fans spin. Attempted to use bios found on here and with other bios the laptop powers on and fans run at full speed and stays running but will not post.
      original bios is attached. Many thanks in advance!
      Badcaps - Capacitor Search Engine & Electronics Repair Forum
      12-08-2023, 06:39 PM
    • legendkray
      BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
      by legendkray
      I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
      07-05-2025, 09:25 AM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • TechMark1
      Alienware 17 Area-51m laptop BIOS dump with Winbond 25Q80DVSIG
      by TechMark1
      I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted. I just zipped it so I could attach it....
      09-21-2025, 03:36 PM
