asusE402B
  • alihomee
    • Dec 2012
    • 1598
    • malaysia
    asusE402B
    mobo code is E402BP ...any one have a working dump
  • DanielDacko
    • Mar 2015
    • 329
    • Macedonia
    Re: asusE402B
    Try this.
    I don't provide help for people using CH341A and a clip.
    • gshark1
      Gaming laptop rtx 2070: Disappearing GPU after BSOD, Only using integrated graphic now
      by gshark1
      Hi, I've exhausted lots of software side options to try and fix why my nvidia 2070 GPU has disappeared from my gaming laptop MSI GL75-10SFK. The system boots and functions normally but only using Intel integrated graphics. Before, it was working fine then began having some blue screens. (I will attach the system event and mini-dump at the end of post). After a few days of the occasional BSODs it finally disappeared from device manager and never came back. I researched and attempted to troubleshoot this issue but im out of options and was wondering if yall had some ideas maybe on the hardware side....
      12-29-2023, 04:42 PM
    • kitor
      HP Pro Mini 400 G9 - Led code 3/6 Processor does not support an enabled feature / disable AMT in dump?
      by kitor
      Hey,
      I got HP Pro Mini 400 G9 waiting for a long time for a CPU. Bought I3-12100T which is on supported list just to receive code 3,6 which says "Processor does not support an enabled feature".
      After research I found this is most likely due to all the management stuff being enabled in BIOS (it has vPRO essentials I5 sticker so that is very likely) where 12100T definitely does not support it.
      Unfortunately I wasn't able to find any friend who would have and lend me their CPU to fix that... so the question is, can this be changed at bios dump level?
      I attached...
      02-03-2025, 11:09 AM
    • FedorovV
      MSI Alpha 15 B5EEK-237XRU Need BIOS working DUMP from a laptop, not from the site.
      by FedorovV
      MSI Alpha 15 B5EEK-237XRU SN:K2209N0193161
      Came without initialization. Before that, it was not under repair. With BIOS from the official website, there is a start Ok, after a while the fans gain speed and the laptop turns off.
      The cooling system is cleaned, the contact spot is good.
      I need a working dump from laptop to check.
      This is an original, not working dump....
      03-10-2024, 07:26 PM
    • tofuSCHNITZEL
      Fujitsu Lifebook E547 vPro
      by tofuSCHNITZEL
      I have a Fujitsu Lifebook E547 vPro that does not boot anymore after Windows Update tried to install a new Bios version. Screen stays black no post - only the numblock light blinks.
      What I've tried:
      I have used my CH341A to read the bios chip (25Q128FVSQ) (Dump attached) - I think the dump is "good" because I could find the Serial number in the data and also the Winkeyfinder found a windows key.
      for the lack of any other Idea I took the bios from this post (https://www.badcaps.net/forum/troubl.../troubleshooti...
      10-15-2025, 04:26 PM
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
