dell latitude 5310 password
    Originally posted by matrixhrg View Post
    please clear me
    Provide the full machine model number, serial number (or Service tag, SNID)
      clear me
      dell latitude 5310 - M.B:19842-1
      Service Tag: DLDN403
      Last edited by Vesko356; 03-28-2024, 02:22 AM. Reason: Attached bios removed, already posted above.
      • Vesko356
        Vesko356 commented
        Editing a comment
        Read the rules before posting
        You MUST:
        • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
      Good Afternoon,
      Can someone help me unlocking this bios file and removing/disabling "Absolute" please.
      This is for a dell 5310
      System Number: DXPW203-8FC8
      Thank you, I appreciate the help.
        Originally posted by mrralvaroa View Post
        Good Afternoon,
        Send to you
          Originally posted by minhdigital View Post
          Send to you
          It worked, thank you so much.
            Hello, can someone help me with this BIOS file reset and remove/disable “Absolute”. Dell Latitude 5310 2 in 1 Service Tag Number: 1G3B403 Thank you, I appreciate the help
              1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
              if that doesn't work, put a bios password and read again and upload here. its easy to spot the hex offset with it.
                When writing to the bois chip, an error message appears.
                  SMDFlea commented
                  Editing a comment
                  Erase the chip, program at a slower speed than 12Mhz
                Thanks, it worked now. but "Absolute" is still active.
                Bios with password attached.
                  try
                    this is what i want 3 hex values needs to be changed. easy to spot with bios password.
                    try
                      "Absolute" is still active and grayed out.
                        try
                          Originally posted by m.sabry2110 View Post
                          try
                          Hello
                          “Absolute” still active
                            Hello
                            Try till you resolve the issue
                              Great, it worked, thank you very much.
                                Finally unlocked +clean me worked for you
                                  Hello!
                                  Can someone help me remove the bios password?
                                  Latitude 5310
                                  Service Tag: 8QRZ563
                                    Originally posted by Echoo View Post
                                    Hello!
                                    Latitude 5310
                                    try
                                      Originally posted by volinakis View Post
                                      try
                                      Thank you very much for your work! It turned out perfect!
