RCUnlocker
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    #161
    Re: RCUnlocker
    Originally posted by Asachan
    Hello RethoricalCheese and thank you ! If you need any more informations let me know ! I try to unlock it by myself too, i'll let you know if i find out .
    I'm also looking for an unlocked g8 spi and ec dump to compare them but no chance so far !
    Try this and let me know.
    • Stefax2001
      • Nov 2021
      • 15
      • Serbia
      #162
      Re: RCUnlocker
      Originally posted by RethoricalCheese
      Looks like your Visual C++ had problems.
      I already reinstalled Microsoft Visual C++ 2015 Redistributable, nothing has changed.
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #163
        Re: RCUnlocker
        Install both x32 and x64 files.
        Become a Badcaps supporter
        Thanks to all supporters.​
        • Stefax2001
          • Nov 2021
          • 15
          • Serbia
          #164
          Re: RCUnlocker
          Thanks, it worked.
          • Diesalweasel
            • May 2016
            • 49
            #165
            Re: RCUnlocker
            hi can i ask a question please . does the rc unlocker support the hp 8470p it has the 16 pin bios chip . . hpbr doesn't support it as tried it tonight under shotgun mode .
            best regards
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              #166
              Re: RCUnlocker
              It does.
              • Asachan
                • Dec 2021
                • 5
                • France
                #167
                Re: RCUnlocker
                Unfortunately i didn't have the chance to try out ... I wrote the bios on the chip and my computer decided to never start again. CPU is fried if i trust the blinking leds. Tried to wrote back both original SPI and EC roms but no luck. I'm pretty sure this is not your fault even tho i don't see where i did a mistake, ever heard of a bad bios frying a component ? Never heard of it so probably nope haha. Maybe i flashed the roms too many times. Anyway, thanks for your help and i'll let you know if i have any luck to try it !
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #168
                  Re: RCUnlocker
                  Usually when this happens, either reading or writing has been the issue. Thatswhy everybody must always use the verify button aswell. No cutting corners.
                  Another thing would be bad soldering of the bios chips.
                  Or battery was not removed when unlocking.
                  • Asachan
                    • Dec 2021
                    • 5
                    • France
                    #169
                    Re: RCUnlocker
                    As i said, it's probably my fault . Still didn't find where i made the mistake tho. Ever heard of someone fixing a thing like this ? I'll start to properly resolder the chips first and check the connections. After that i'm kinda out of ideas haha.
                    • RethoricalCheese
                      • Mar 2013
                      • 1519
                      • Estonia
                      #170
                      Re: RCUnlocker
                      Lately I've seen a few 840 G5 die of excessive heat when unsoldering and soldering bios chip. Otherwise, no.
                      • Asachan
                        • Dec 2021
                        • 5
                        • France
                        #171
                        Re: RCUnlocker
                        I will work on it soon, will let you know if i have any news. Thanks again for the help !
                        • Diesalweasel
                          • May 2016
                          • 49
                          #172
                          Re: RCUnlocker
                          Hi can someone check this file for me please . when i drag it to rc unlocker i get an error message saying missing unlockable content .
                          i can only assume it the connection what the issue . but if i try with hp unlocker it says unlocked the laptop in question is hp 8470p
                          best regards
                          • RethoricalCheese
                            • Mar 2013
                            • 1519
                            • Estonia
                            #173
                            Re: RCUnlocker
                            hpunlocker has no content verification (I was kinda hoping that people know how to read and check what they read from their chip. But that was too naive of me. So RCUnlocker has half of its code just for verification)
                            Your readout is garbage. Try again WITH using verify button. How many times do I have to tell it?
                            • Diesalweasel
                              • May 2016
                              • 49
                              #174
                              Re: RCUnlocker
                              hpunlocker has no content verification.
                              cheers i thought it was i used a cheap Chinese clip . i will solder the wires to it
                              • NTBservis
                                • Jun 2016
                                • 33
                                • Czech
                                #175
                                Re: RCUnlocker
                                I have problem with unlock HP ProBook 4545s. After using RCUnlocker it still requires logon's bios.
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #176
                                  Re: RCUnlocker
                                  • NTBservis
                                    • Jun 2016
                                    • 33
                                    • Czech
                                    #177
                                    Re: RCUnlocker
                                    Working
                                    Thanks.
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      #178
                                      Re: RCUnlocker
                                      Working
                                      Thanks.
                                      You're welcome.
                                      • dycc
                                        Vision
                                        • Nov 2011
                                        • 626
                                        • Côte d'Ivoire
                                        #179
                                        Re: RCUnlocker
                                        HP EliteBook 840 G8 unlocked with hex editor without your tool. i know it can but you had to remove 128Mbit bios limit
                                        • RethoricalCheese
                                          • Mar 2013
                                          • 1519
                                          • Estonia
                                          #180
                                          Re: RCUnlocker
                                          So nvramactiveregn still?
                                          It's easy to remove the limit but I have to stop people from using it on main bios then. But I have an idea. Will try to do it next week.
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
