RCUnlocker
  • fossil_fusca
    • Oct 2025
    • Uruguay
    #1281
    When I drag the 32-bit .bin file to the RCUnlocker.exe it tells me to modify the file to make it 16mb. How can I do that? Can someone help me? I also need to know which of the BIOS chips contains the NVRAM because I have a HP 805 G6 mini PC that has two identical 32mb chips in two different places on the board and I don't know which one I have to read, unlock, and write.
    • peste
      • 14025
      • ROMANIA
      #1282
      on both...use the HxD program (you can find it for free) cut the 32MB bios into 2x16MB use RCUnlocker on both 32MB bios, merge them and write them...be sure to make backup copies without errors so you don't have problems later...
      • cyclopzz
        • Oct 2025
        Hi tried RCUnlocker on hp probook 440 g7 to remove bios admin password but did not work please help?
        have attached original and unlocked bins
        HP ProBook 440 G7
        System Bios S71 Ver. 01.21.00
        Serial Number 5CD0152SW6
        SKU Number 8VU02EA#ABU
        System Board ID 869D
        System Board CT Number PJPNC028JDKOPU
        • Tammani
          • Oct 2025
          • Algeria
          #1284
          Hello totally tech outsiiider need help pleaaaase the exact steps i have an HP EliteBook 840 G8 Notebook PC
          • fossil_fusca
            • Oct 2025
            • Uruguay
            #1285
            peste thankyou Partner i will probe and tell you later, i know about of HxD software but i dont know how cut and merge the files but i will learn , because i only use the HxD for compare files, thanks.
            • forgotten
              • Jul 2018
              • iran
              #1286
              working on hp probook 640 g1
              reset Admin pass
              thanks
              • Hijlko
                • Nov 2025
                • Nederland
                #1287
                My HP ProBook 650 G1 has a bios that reports "System Information Not Valid". I want to edit the system information with the Windows version of NbDmiFit14 on a WinPE USB stick.
                The tool reports that the bios is locked. I tried RCUnlocker but it won't make an unlocked file because of "missing information". I also tried HPUnlocker. That makes a new file but when I try to updae the bios with this new file, it's not unlocked.
                Can someone help me unlock the bios or give me a link to a tool that does the job? Or a goed 'how to' do al this?
                Here is my backed up bios file.
                Serial Number is 5CG50936LL
                • Devknight
                  • Nov 2025
                  • Usa
                  #1288
                  Hi there. First time posting. Was hoping I could be given instructions to unlock my hp elite book 8470p. The bios has a password and I don't get any tips hints or codes when entering it incorrectly. Downloaded the tool just need to know what to do so I don't brick my device.
                  • Progwhiz
                    • Nov 2025
                    • Trinidad
                    #1289
                    Originally posted by Stefax2001
                    Re: RCUnlocker
                    Can somebody help me, why I'm getting "VCRUNTIME140.dll was not found" error?
                    install vcc++ redistributable both 64bit and 32bit versions and reboot. Although I think it only needs the 32bit version
                    • Homofiss
                      • Dec 2025
                      • Deutschland
                      #1290
                      Hello.
                      I tried to use your tool, but got that message attached to try a 16MB chip.
                      If i read your notes correct, Zbooks up to 32MB are suported. May I missunderstood your comments or did something wrong.
                      Could you help me pease.
                      bin file and some details are attached.
                      HP zBook Fury15.6 G8
                      Chip: W25Q256JV - 32 Mbytes
                      thanks.
                      • faik_guler
                        • Apr 2017
                        • 6
                        • gebze
                        #1291
                        Hello, I have a similar problem. When I try it with a Zbook 15 G6, I have a 32 MB BIOS file and I get a warning that it supports a 16 MB chip. Can you help?
                        • peste
                          • 14025
                          • ROMANIA
                          #1292
                          post S/N, full name and model, motherboard model, product number,etc.
                          post the original contents of the bios chip..
                          • faik_guler
                            • Apr 2017
                            • 6
                            • gebze
                            #1293
                            I just found a Python script. I tried it, but after inserting the chip, it asked for the password again. It didn't work. I'll be waiting for the file from you, thank you very much. peste
                            • faik_guler
                              • Apr 2017
                              • 6
                              • gebze
                              #1294
                              Originally posted by Homofiss
                              Hello.
                              thanks.
                              Hello everybody, I solved the problem. There are two BIOS chips on the motherboard: one is 16 MB and the other is 32 MB.
                              First, I used the HxD program to split the 32 MB BIOS file into two parts: Part 1 (16 MB) and Part 2 (16 MB). Then, I dragged each part into the RCUnlocker program. RCUnlocker didn't make any changes to Part 1, but it did make some modifications to Part 2. After that, I merged the two files back together, obtaining a 32 MB BIOS file again.
                              Next, I also dragged the 16 MB BIOS file from the second chip into RCUnlocker, and it completed the process on that file as well.
                              I flashed the new files to both BIOS chips, installed them in the device, and it booted up with the passwords cleared.
                              Note 1: When I only performed this process on the 32 MB chip, the device still asked for a password.
                              Note 2: I did not try processing only the 16 MB chip by itself, so I don't know if that alone would have worked.
                              Note 3: The problem is definitely fixed when both the 32 MB and 16 MB chips are re-flashed.
                                HP Clean VSS2 dumps,fix Endpoint Security error
                                by SMDFlea
                                Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                the infamous **"Endpoint Security" error message.
                                Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                files.
                                hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                filling everything after...
                                08-08-2024, 03:14 PM
                                HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-07-2024, 07:12 AM
                                09-07-2024, 06:40 AM
                                HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                09-07-2024, 05:50 AM
