RCUnlocker
  • shaggysound
    • Jan 2025
    • UAE
    #1181
    I have 3 Elitedesk 800 G6 SFF PC with password locked BIOS.
    Product Number (same for all 3): 8YM57AV
    Serial Numbers: CZC1239T57
    CZC1239T5L
    CZC1239T3X
    The boards are all the same revision (Cersei Rev A)
    There are two chips near the BIOS markings (Images Attached):
    8 pin Giga Device 25B127DSIG
    16 pin 25B256DFIG
    I have a programmer on order, it only has 8 pin test leads.
    Can you confirm the 8 pin 25B127DSIG is the chip of interest to RCUnlocker and that the tool works with this model of computer?
    Thank you.
    • GeminisK
      • Jan 2025
      • 12
      • spain
      #1182
      Originally posted by GeminisK
      I will try tomorrow, thanks!
      Dont work… Thanks.
      I will make a last try with one from the hp t99 page according to the support, if it doesn't work, I will put the laptop for sale...
        • 21467
        Dont work… Thanks.
        You were asked to post both files https://www.badcaps.net/forum/troubl...31#post3546731
        You have only posted the main bios, there is another chip , not sure if thats also 32MB or 16MB, but there is one somewhere on the board, maybe on the other side, when you find it post the backup.
        • GeminisK
          • Jan 2025
          • 12
          • spain
          #1184
          Hello, I only have one bios on the board, it is 32mb, this is the original one.
          hp probook 450 g8
          Buildid:20wwr3BT601#SABE#DABE
          27J69EA#ABE
          BIOS: 25Q256JVEQ 3.3v
          SN: 5CD0518SR5
          I would like to have a clean bios or remove the password.
          Thank you!!!
            • 21467
            hp probook 450 g8
            27J69EA#ABE
            SN: 5CD0518SR5
            Thank you!!!
            I have removed the bios attachment, you have already posted it twice in this thread, there is no need to post it again. There IS another chip on the board, and its 32MB, find it,look under the plastic ,look everywhere.look for SOP8 or WSON8 chips .
            • GeminisK
              • Jan 2025
              • 12
              • spain
              #1186
              Sorry for the misunderstanding, is:
              gigadevice 25b256dyig u9f154 aj2016
              I will get this bios out and upload it as soon as possible!!! thanks!!
              do you know with which program I can read it? asprogrammer 2.0, CH341A and NeoProgrammer not.... is impossible :/ how can I read it?
              • shaggysound
                • Jan 2025
                • UAE
                #1187
                16 pin 25B256DFIG
                My CH341A arrived. After modding it to 3.3v I have successfully removed the bios password for my first system with RCUnlocker and NEO Programmer. I can confirm the 8 Pin 25B127DSIG is the correct chip to flash.
                Here are some notes if anyone else is a novice like me:
                1: For this model RCUnlocker just displayed "Unlock Success"
                2: I used the GD25Q127C profile in NEO Programmer as there isn't one for the chip.
                3: In NEO-Programmer I had to select all 5 options for write IC - Off-protect, Erase, Blank Check, Write, Verify. Without this selected it would not write.
                  • 21467
                  You can choose a different 256 chip from the list or add the chip to the NeoProgrammer support list
                  How to add chip support to NeoProgrammer software for the CH341A Programmer https://www.badcaps.net/forum/troubl...41a-programmer
                  Click image for larger version  Name:	Gigadevice.jpg Views:	0 Size:	13.5 KB ID:	3552352
                  id="C84019"
                  page="256"
                  size="33554432"​
                  • GeminisK
                    • Jan 2025
                    • 12
                    • spain
                    #1189
                    id="C84019"
                    page="256"
                    size="33554432"​
                    I have broken the pins of the chip.... now I have to buy another one, I have not been able to get your information.... is there a possibility to have clean bios for both chips? or the pc is useless?
                      • 21467
                      There is a possibility to recover from this latest disaster yes, but it will involve more work as you`ll have to fill new DMI info, thats another challenge. When you get the new chip let us know.
                      • judynar
                        • Mar 2023
                        • philippines
                        #1191
                        Originally posted by RethoricalCheese
                        This is a multitool and unlocker for several series of laptops. Works on Windows. No python etc installing needed, all included in package. Everything is tested by myself but since every laptop is not made equally, there might be edge cases. Always VERIFY your file after reading!!!
                        Unlocking
                        HP - ProBook, EliteBook, ZBook (including 32MB models)
                        Chromebooks from all various manufacturers
                        Apple - everything older than T2
                        More to come...
                        Information display (helps to verify file integrity)
                        HP - ProBook, EliteBook, ZBook (up to 16MB models for now)
                        Custom logo removal
                        Usage: Drag and drop .bin file to .exe file.
                        In case there are problems with unlocking your laptop, write a short description of the issue, upload original file and if possible, _unlocked.bin file aswell. Just crying for help is useless. Keep the topic as clean as possible.
                        You may ask for feature requests, I'll see what I can do.
                        i got this problem sir hello im from PH
                        • FaissalDZ
                          • May 2018
                          • 46
                          • Algeria
                          #1192
                          I tried to unlock my HP ProBook 5330m with this tool and I got this error (in the image below)!
                          HP ProBook 5330m
                          Serial: CNF1400VLB
                          Product: LG723EA#ABF
                          What is the problem please?
                          • peste
                            • 13199
                            • ROMANIA
                            #1193
                            HP ProBook 5330m
                            Serial: CNF1400VLB
                            write it like this on the chip with error, it's ok..try..
                            • FaissalDZ
                              • May 2018
                              • 46
                              • Algeria
                              #1194
                              Thanks,
                              I compared the 2 files by HXD editor and I found them the same file.
                              • Stanciu Mihai
                                • Jan 2025
                                #1195
                                I tryed to unlock my HP Zbook 15 G3 and i received this error. I Download the vcruntime140 dll and put on the app folder, but wan't want to start. could you please help me what I need tot do to can start the app?
                                • azanwaqas771
                                  • Feb 2019
                                  • 48
                                  • Pakistan
                                  #1196
                                  first extract this and after copy this file paste in C:\Windows\SysWOW64 and C:\Windows\System32
                                    • 21467
                                    Get dll files from the official microsoft installers. https://www.badcaps.net/forum/troubl...88#post1655388 ,install the 32 and 64 bit versions
                                    Latest Microsoft Visual C++ Redistributable Version https://learn.microsoft.com/en-us/cp...?view=msvc-170
                                    • Stanciu Mihai
                                      • Jan 2025
                                      #1198
                                      It worked after I installed both versions.
                                      Thanks!
                                      • GeminisK
                                        • Jan 2025
                                        • 12
                                        • spain
                                        #1199
                                        this one fits me? even if this one: u9f154 aj2016 is different? the only important thing is that the model is 25b256dyig? please confirm to buy it as soon as possible.
                                        https://es.aliexpress.com/item/10050...Cquery_from%3A
                                          SMDFlea commented
                                          Editing a comment
                                          it is ok.if it says 25b256dyig.
                                      • adamgouadma
                                        • Jul 2017
                                        • 195
                                        • setif
                                        #1200
                                        Thank you RethoricalCheese
                                          HP Clean VSS2 dumps,fix Endpoint Security error
                                          by SMDFlea
                                          Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                          the infamous **"Endpoint Security" error message.
                                          Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                          I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                          The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                          files.
                                          hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                          filling everything after...
                                          08-08-2024, 03:14 PM
                                          HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-07-2024, 07:12 AM
                                          09-07-2024, 06:40 AM
                                          HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                          This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 05:50 AM
