RCUnlocker
  • saeid1360
    • Jan 2024
    • 5
    #1041
    Originally posted by hoaca388
    XXX
    i write new file but after i dont have any pictuer on lcd
    matherbord dead
    • vzgherea
      • Sep 2018
      • 16
      Failed to unlock an HP Elitebook 840 G5.
      Chip is 32Mb.
      After replacing the original BIOS the admin password is still there.
      Attaching the original file and the patched one.
      Please take a look and let me know if you see where the problem is.
      • rex98
        • Feb 2023
        • 1241
        • Mandaue CEBU, Philippines
        #1043
        Chip is 32Mb.
        first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
        after following my instruction to get rifd of Manufacturing mode. use BCU. or flash the original main.
        • vzgherea
          • Sep 2018
          • 16
          Worked like a charm, thank you!
          • Guest
            #1045
            HP Probook 650 G1 - Need to remove bIOS admin password.
            I'm a newbie and do not want to throw out the laptop as yet.
            Serial # CNU416D98Z Prod# G3C19US#ABA
            CH341 Mini programmer with ASProgrammer 2.0
            I've also tried the application that comes with CH341 and Neoprogrammer.
            Marking on IC: W25Q128FVSQ
            using miniprogrammer 25 series and clipped to the IC chip.
            Unable to grab a dump without crc errors and all FFFF's
            See my screenshot of the error and the programmer setup.
            What am I doing wrong?
            Looking for suggestions?
            -if I unsolder the chip - can it be tested in my mini programmer or do I need to buy more adapters?
            -do i unsolder the chip and buy a new one?
            -do I ask for a dump file and overwrite it on the chip?
            TIA.
            • peste
              peste commented
              Editing a comment
              post moved..
            • 20405
            Is the chip type SOP8 (with legs) or WSON8 (no legs,flat on the motherboard) .What adapters did you get with the programmer,if any
            • simo1234
              • May 2024
              • 5
              • Maroc
              #1047
              hello hp pavilion x360 2-in1 no display SN 8CG3060CR2
            • DonZott
              • Apr 2014
              • 8
              • Belgium
              #1048
              TIA.
              I have done many Probook 650 G1 before, it's best to desolder the IC.
              It should be possible to solder the IC on the PCB where your IC clip is connected to.
              • Echoo
                • Apr 2018
                • 80
                • Budapest
                #1049
                Hello!
                HP ProBook 455 G7 25Q128JVSQ chip (BIOS label next to it). I read it, opened it with RC-Unlocker, but it still asks for the password. I also tried HP Unlocker, but the same thing happened. Why can't I delete the password?
                HP ProBook 455 G7
                SN: 5CD044CNZZ
                Motherboard: X9M
              • Echoo
                • Apr 2018
                • 80
                • Budapest
                #1050
                Dear Peste!
                I just forgot, I was thinking about what could be wrong, it distracted me! I apologize!​
                • Guest
                  #1051
                  Reply to SMDFLea
                  Chip is SOP8 with legs. heres the amazon.ca order link that shows the adapters we rec;d, If we unsolder the chip do I just use the clip to test with ?
                  https://www.amazon.ca/Organizer-EEPR...p_sim_0_t&th=1
                  • peter81
                    • Jun 2024
                    • Netherlands
                    #1052
                    did not work for a HP ProBook 4520s BIOS gave error UnicodeDecodeError: 'utf-8' codec can't decode byte 0xff in position 3: invalid start byte
                    • peste
                      • 12290
                      • ROMANIA
                      #1053
                      post the bios here S/N, etc...
                      • K53ww
                        • Jun 2024
                        • 7
                        Tried RCUnlock out but HP Elitebook 2530p refuses to display when trying to boot. I can send the file
                        • moh17
                          • Feb 2018
                          • 27
                          • Algeria
                          #1055
                          Great job
                          • mustafa0606
                            • Jul 2024
                            • Deutschland
                            #1056
                            Originally posted by RethoricalCheese
                            This is a multitool and unlocker for several series of laptops. Works on Windows. No python etc installing needed, all included in package. Everything is tested by myself but since every laptop is not made equally, there might be edge cases. Always VERIFY your file after reading!!!
                            Unlocking
                            HP - ProBook, EliteBook, ZBook (including 32MB models)
                            Chromebooks from all various manufacturers
                            Apple - everything older than T2
                            More to come...
                            Information display (helps to verify file integrity)
                            HP - ProBook, EliteBook, ZBook (up to 16MB models for now)
                            Custom logo removal
                            Usage: Drag and drop .bin file to .exe file.
                            In case there are problems with unlocking your laptop, write a short description of the issue, upload original file and if possible, _unlocked.bin file aswell. Just crying for help is useless. Keep the topic as clean as possible.
                            You may ask for feature requests, I'll see what I can do.
                            • peste
                              peste commented
                              Editing a comment
                              ok ... and what is the problem?? post the name, the complete model of the laptop, the motherboard model, S/N, the original bios... what can we understand from this picture????
                          • xikmat
                            • Mar 2016
                            • 6
                            • Uzbekistan
                            #1057
                            quanta x9s 32mb 2x amd
                            password this utilit not supported now!
                            • realclassics2
                              • May 2023
                              • Deutschland
                              #1058
                              unfortunately rcunlocker is not running on my PC. Could maybe somebody unlock my BIOS-file attached?
                              • peste
                                • 12290
                                • ROMANIA
                                #1059
                                post the S/N, , the motherboard model, the full name and model of the laptop,etc.
                                • realclassics2
                                  • May 2023
                                  • Deutschland
                                  #1060
                                  HP ProBook 650 G1
                                  PCID: A3009CD10303
                                  Serial: 5CG5455JLK
                                  Product: K1N98EC#ABD
                                  BIOS-Chip: 25L12873F
                                    HP Clean VSS2 dumps,fix Endpoint Security error
                                    by SMDFlea
                                    Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                    the infamous **"Endpoint Security" error message.
                                    Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                    I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                    The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                    files.
                                    hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                    filling everything after...
                                    08-08-2024, 03:14 PM
                                    HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                    This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-07-2024, 07:12 AM
                                    09-07-2024, 06:40 AM
                                    HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                    This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                    09-07-2024, 05:50 AM
