RCUnlocker
  • RethoricalCheese
    • Mar 2013
    • 1514
    • Estonia
    #61
    Re: RCUnlocker
    Ecaxtly. SPI programmer is mandatory.
    • tedypm2000
      • Sep 2021
      • 7
      #62
      Re: RCUnlocker
      Ok, thanks for the reply.
      Is there any risk that by utilizing this process/approach with the SPI and your software, the BIOS with brick / become invalid so I won't be able to recover it to the initial state? If it does fail/doesn't work can I revert it to its initial state or will that be the end of the laptop?
      • RethoricalCheese
        • Mar 2013
        • 1514
        • Estonia
        #63
        Re: RCUnlocker
        Just back up both main and EC content (and be sure to verify both), then there won't be any problems.
        • tedypm2000
          • Sep 2021
          • 7
          #64
          Re: RCUnlocker
          That would also be done with the SPI programmer, correct?
          Thanks for your replies so far, appreciate the help.
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #65
            Re: RCUnlocker
            Yep
            Become a Badcaps supporter
            Thanks to all supporters.
            • jsinfo
              • Oct 2018
              • 10
              • Indonesia
              #66
              Re: RCUnlocker
              They use completely different code so doesn't help much. Do you have all of the files in folder like they came from the rar or did you copy it somewhere else without other files included?
              Yes I extracted it with 7-zip and everything is there. I also tried to run the program on win 10 and still there was error message. It might need windows 32bit. Anyway thank you very much for the programs.
              • RethoricalCheese
                • Mar 2013
                • 1514
                • Estonia
                #67
                Re: RCUnlocker
                I havent used 32 bit for ages so this makes no sense
                • mygerges
                  • Sep 2021
                  • Egypt
                  #68
                  Re: RCUnlocker
                  Can I use this program for Probook 450 G6 and how?
                  • IntelliDroid
                    • Sep 2021
                    Re: RCUnlocker
                    I am trying to use the tool and it is saying 'Missing File Destination Argument!'. I have a HP Zbook 14u G6. It has HP Surestart enabled as well.
                    What do I need to make us of this tool and remove the password from the bios?
                    This help would be greatly appreciated, thank you!
                    • tedypm2000
                      • Sep 2021
                      • 7
                      #70
                      Re: RCUnlocker
                      You need a BIOS dump obtained using an SPI programmer, then using that dump with this software. Read my comments from this page (#4) and from the previous page (#3)
                      • tedypm2000
                        • Sep 2021
                        • 7
                        #71
                        Re: RCUnlocker
                        Originally posted by Vesko356
                        Yep
                        Thanks for the reply! I see you're from Bulgaria. Hello, neighbor!
                        One last thing, if you don't mind:
                        Since I'm about to buy the SIP Programmer, would you be so kind as to confirm if I need a specific one based on my BIOS chip?
                        As I said, my laptop is an HP Elitebook x360 1030 G3 - it has Hp Sure start, bios password, and so forth.
                        Will the SIP programmer CH341A + SOIC8 be what I need for the BIOS chip on the laptop or do I need something else? Read somewhere that it depends on the type of BIOS chip the laptop has, which requires visual confirmation. Is that true or should I just buy this programmer I mentioned?
                        Thanks again
                        • jsinfo
                          • Oct 2018
                          • 10
                          • Indonesia
                          #72
                          Re: RCUnlocker
                          I see. I will figure out why I couldn't run it. By the way do you have the source code for the program?
                          • tedypm2000
                            • Sep 2021
                            • 7
                            #73
                            Re: RCUnlocker
                            Thanks again
                            Adding pictures in case they matter:
                            Far view: https://ibb.co/SQ52Wrg
                            Close view: https://ibb.co/KxJtPMM
                            We can see serial # and stuff. Which one of these three is it that I need to use the SIP on?
                            I can open a separate thread if I'm spamming this one with my posts. Sorry about that if that's the case. let me know
                            • jsinfo
                              • Oct 2018
                              • 10
                              • Indonesia
                              #74
                              Re: RCUnlocker
                              The SPI is 25Q128... I think you can use SOIC8 for this kind of chip. You can either connect the wire to its pins or take it out with solder.
                              • Siddig
                                • Jun 2017
                                • 264
                                • Sudan
                                #75
                                Re: RCUnlocker
                                This is a multitool and unlocker for several series of laptops. Works on Windows. No python etc installing needed, all included in package. Everything is tested by myself but since every laptop is not made equally, there might be edge cases. Always VERIFY your file after reading!!!
                                Unlocking
                                HP - ProBook, EliteBook, ZBook (including 32MB models)
                                Chromebooks from all various manufacturers
                                Apple - everything older than T2
                                More to come...
                                Information display (helps to verify file integrity)
                                HP - ProBook, EliteBook, ZBook (up to 16MB models for now)
                                Custom logo removal
                                Usage: Drag and drop .bin file to .exe file.
                                In case there are problems with unlocking your laptop, write a short description of the issue, upload original file and if possible, _unlocked.bin file aswell. Just crying for help is useless. Keep the topic as clean as possible.
                                You may ask for feature requests, I'll see what I can do.
                                its dosnt work. show me this message :Missing file destination argument
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1514
                                  • Estonia
                                  #76
                                  Re: RCUnlocker
                                  Well, did you read what you quoted? The usage part to be exact.
                                  • black0hackers
                                    • Jul 2020
                                    • 365
                                    Re: RCUnlocker
                                    done on HP ELITE X2 1013 G3. thank you pro!
                                    • LatinMcG
                                      • Jun 2015
                                      • 70
                                      • USA/Puerto Rico
                                      #78
                                      Re: RCUnlocker
                                      here i have a Dell inspiron 5300 Chromebook that cant unlock.
                                      heres my unlock method bin file compare that worked.
                                      hope u can add for newer ones
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1514
                                        • Estonia
                                        #79
                                        Re: RCUnlocker
                                        Yeah, thanks, but I know how it works, I just havent seen chromebooks with 32MB chips so I just disabled 32MB file usage because of newer HP-s Will find another way some day.
                                        • vinsun0399
                                          • Aug 2019
                                          • 38
                                          • Jakulin
                                          #80
                                          Re: RCUnlocker
                                          pls help me
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
