RCUnlocker
+ More Options
Posts
  • ogre4273
    • Mar 2022
    • 57
    • N/A
    #461
    Re: RCUnlocker
    Originally posted by AAAC
    @ogre4273
    Use UEFITool NE version and check UEFI Variables, there's usually one named AbtState, that one contains information if Absolute Computrace is Active.
    Then use an hex-editor and search for AbtState, a few bytes before the string you will find the header AA553F(h), to invalidate that variable make it AA553C(h), save changes.
    Do I need to do that on the 32mb bios dump? or I also need 16mb?
    My laptop is HP Elitebook 840 G6, is it applicable?
    • ogre4273
      • Mar 2022
      • 57
      • N/A
      #462
      Re: RCUnlocker
      @AAAC
      There is indeed AbtState (see the pic below) so I need to change "F" to "C" right?
      What I think is that the computrace will be still active because I only modify the 32mb dump. Is there any other way to also disable it on 16mb dump?
      • AAAC
        • Jan 2020
        • 459
        • Mexico
        #463
        Re: RCUnlocker
        @ogre4273
        Is CompuTrace really ACTIVE? Because when it’s Active there’s an ASCII string (account number?) in the lines below AbtString.
        • ogre4273
          • Mar 2022
          • 57
          • N/A
          #464
          Re: RCUnlocker
          @ogre4273
          Is CompuTrace really ACTIVE? Because when it's Active there's an ASCII string (account number?) in the lines below AbtString.
          Oh is that so, then I analyze it further. About this dump, I just found it in the forum just to see what that AbtState looks like. I'm dumping my own bios when I received EZP2019 that I ordered. Thank you for your help and I'll be back shortly.
          • ogre4273
            • Mar 2022
            • 57
            • N/A
            #465
            Re: RCUnlocker
            @AAAC
            so when removing computrace I only need to modify the main bios which is the 32mb? Sorry for asking, just making sure so that I can save some time without removing the whole board for the 16mb chip. Thank you again.
            • AAAC
              • Jan 2020
              • 459
              • Mexico
              #466
              Re: RCUnlocker
              @ogre4273
              On the ones I’ve done, just modifying the 32MB chip contents is enough.
              • ogre4273
                • Mar 2022
                • 57
                • N/A
                #467
                Re: RCUnlocker
                @AAAC
                Thank you for your help! I'll come back if it's successful. I hope I'll be able to remove it so that I would not spend money for patching my bios bin to remove it. Some people offering me 40 dollars just to patch it. Is your method same as them?
                • AAAC
                  • Jan 2020
                  • 459
                  • Mexico
                  #468
                  Re: RCUnlocker
                  I believe so.
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    #469
                    Re: RCUnlocker
                    Removing it from bios does not remove it from their servers.
                    So there will probably be an issue when the next user tries to sign up for computrace. But if not, this works fine.
                    There are people who have official tools to remove both from server and bios. But since it goes through their servers and users IP has to be whitelisted first, it's no use to anybody who is not approved.
                    That said, you could probably get it removed server-side just by sending them your SN and asking it to be removed.
                    • ogre4273
                      • Mar 2022
                      • 57
                      • N/A
                      #470
                      Re: RCUnlocker
                      Hello @RethoricalCheese !! What do you mean by next user sign up? If I remove or make computrace inactive from the bios does it mean that it will be active again sometime in the future? And what will happen to the server side if I managed to remove it?
                      • RethoricalCheese
                        • Mar 2013
                        • 1519
                        • Estonia
                        #471
                        Re: RCUnlocker
                        If you disable it and never ever want to use it then it will not return. No problems at all. Laptop will not try to query computrace so nothing will happen.
                        But if the next user really wants to use computrace, it most probably won't work because the SN is tied to previous computrace client.
                        So if you or the next user does not want it to work then there will be no problems when you just patch bios. It's mostly for business clients anyway so if you don't resell to businesses, there won't be an issue.
                        • chypnotic
                          • Jul 2019
                          Re: RCUnlocker
                          I believe so.
                          840 G7 Absolute Persistence Active
                          Hi AAAC, could you please help me to remove computrace? the BIOS has no password, but hp absolute persistence is active, My model is a 840 G7. I will be very grateful, please, thank you
                          • AAAC
                            • Jan 2020
                            • 459
                            • Mexico
                            #473
                            Re: RCUnlocker
                            @chypnotic
                            How did you read this BIOS file? If you used a programmer, which programmer did you use?
                            To me seems like the file is incomplete, by the model number it should be 32MB, maybe there's another chip.
                            • chypnotic
                              • Jul 2019
                              Re: RCUnlocker
                              @chypnotic
                              I have removed only the 16 meg 25Q128JV chip with the SOFI SP8-F programmer. The chip had a password to enter the Bios, but using the RCUnlocker program, I have managed to erase the password, but now I find that computrace is active, would you help me remove it please? Thank you
                              • ogre4273
                                • Mar 2022
                                • 57
                                • N/A
                                #475
                                Re: RCUnlocker
                                @AAAC
                                hello again, I managed to get my bios dump both 32mb and 16mb.
                                Can I disable computrace if Manufacture Programming Mode is enabled?
                                and if not, would you unlock it for me? I would attach it here if you want. Thank you!
                                • ogre4273
                                  • Mar 2022
                                  • 57
                                  • N/A
                                  #476
                                  Re: RCUnlocker
                                  @AAAC
                                  UPDATE:
                                  @AAAC
                                  Forget about this text that I quoted. I found out that there is a number below Abtstate, should I remove it or just change AA553F to AA553C? The picture is attached below.
                                  • AAAC
                                    • Jan 2020
                                    • 459
                                    • Mexico
                                    #477
                                    Re: RCUnlocker
                                    @ogre4273
                                    Invalidating the variable should be enough. After you do it and open the new BIOS file with UEFITOOL NE version, you will find that now it will show as Invalid.
                                    • Robien
                                      • Mar 2014
                                      • 27
                                      Re: RCUnlocker
                                      @RethoricalCheese
                                      sir i tried with 32mb chip but fail
                                      would you add 32mb please
                                      • ogre4273
                                        • Mar 2022
                                        • 57
                                        • N/A
                                        #479
                                        Re: RCUnlocker
                                        @ogre4273
                                        @AAAC
                                        Okay, I'll do it. Last question.
                                        the 16mb chip is not needed right?
                                        So what I will do is get the latest dump of my 32mb bios (will dump it 3x to be sure) and then invalidate the hex 3F to 3C then flash it again? then that's it? Sorry if I ask too many questions. Thank you!
                                        • AAAC
                                          • Jan 2020
                                          • 459
                                          • Mexico
                                          #480
                                          Re: RCUnlocker
                                          @ogre4273
                                          I've been modifying only the 32MB chip.
                                          Dump and save the file 3 times, then check all 3 files are identical (if you use a utility like WinRAR or similar, you can ZIP or RAR the files, then open the ZIP or RAR resulting file, on the far right there's a column with CRC32 values, if all they match all the files are exact copies).
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
