need bios for acer asprie 3820tg
  • String2016
    • Nov 2015
    • 2242
    • philippines
    I need a working bios on acer 3820tg 09921-3 48.4HL01.031 please
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: need bios for acer asprie 3820tg
    Try
    Become a Badcaps supporter
    Thanks to all supporters.​
    • String2016
      • Nov 2015
      • 2242
      • philippines
      thanks its working
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        thanks its working
        You're welcome
        • String2016
          • Nov 2015
          • 2242
          • philippines
          update: after a days working it shows in boot up 210 cpu variable mtrr error, but pressing f1 laptop continues and boots fine, tried replacing ram and update the bios still showing on start up anyone can help this
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Try replacing the BIOS chip itself, it's likely old and no longer holding the data properly.
            A working TV? How boring!
            • TyMercer
              Can I flash a working BIOS from one computer to another of the same make, model, etc?
              by TyMercer
              Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
              11-13-2025, 09:39 PM
            • titomno2
              Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
              by titomno2
              Hi guys,
              On motherboard ACER AN515-52 type LAF951P.
              I fixed issue with not starting computer (it was the PQ201 component not working properly).
              But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
              Basically some HDD spin but are not detected by the bios.
              Already tried following:
              checked the 4 data lines
              #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
              #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
              07-28-2024, 08:30 AM
            • Simon Halley
              Need working bios for Acer Nitro 5 AN515-56
              by Simon Halley
              Needing a working bios for an Acer Nitro 5. Help would be really appreciated.
              AN515-56-58EE
              Model: N20C1
              Serial No: NHQBZSA00112003B723400
              SNID: 12001521834
              Mainboard: GH52T LA-L051P
              Rev: 1A
              2021-01-25
              (see attached, the non-working bios)...
              08-11-2025, 03:09 AM
            • Mounier
              Bios a working EC for Acer Predator Helios 300
              by Mounier
              I need a working bios & a working EC for my Acer predator Helios 300 PH317-51- 73XK
              SNID 74605868734
              S/N: NHQ2MEF0077460E53F3400
              Thanks for anyone who can help.
              Stéphane
              11-26-2025, 06:53 AM
            • ub6ib969
              Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
              by ub6ib969
              Model Number: PO3-650
              Part Number: DG.BK4AA.006
              Serial Number : 33400117730
              BIOS IC : XM25QH256C
              I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...
              07-02-2025, 03:51 PM
