ThinkPad t460s Patched Bios Request
    • 20279
    Originally posted by kingstonalumni
    Thinkpad T460s, BT460 NM A421 Rev 4.0 (2016-04). Type 20FA-A0V6VA. S/N : PC-0KFYMH 17/03. Any help unlock administrator password, tks
    Have you tried the lenovo Autopatcher ? https://www.badcaps.net/forum/troubl...71#post1798371
    • kingstonalumni
      • Oct 2023
      • 16
      • VIETNAM
      #42
      it works, thanks for support
      • afcp
        • Sep 2024
        • Portugal
        #43
        Hello. I try lenovo Autopatcher but i don´t understand. I download bios file throug lenovo but i can´t see the BIN file. If i flash the original firmware it´s completed but i don´t understand as flash the autopacther. Thnaks for your work
        • hoaca388
          • Jan 2022
          • 11135
          • Viet Nam
          #44
          Lenovo Autopatcher is a patch generator to bypass the password. Just drag and drop the file to be unlocked into "autopatch.cmd" .
          Become a Badcaps supporter
          Thanks to all supporters.
          • afcp
            • Sep 2024
            • Portugal
            #45
            Yes i know. But i don’t have the bin file
            • hoaca388
              • Jan 2022
              • 11135
              • Viet Nam
              #46
              Yes i know. But i don't have the bin file
              The .bin file is your locked bios file.
              You have to buy a programmer, for example CH431A (this is the cheapest one) and learn how to use it.
              https://www.youtube.com/results?sear...+how+to+use​
              • JSanthony
                • Feb 2025
                • 5
                • México
                #47
                Originally posted by brontobyte
                Hello, i have few t460s 20FA with administrator password. I need patched bios or any solution to unlock them.
                Here is my original BIOS! THANK YOU !
                T460s BT460 NM-A421 rev 3.0
                Hi, I need your help... I have a thinkpad t460s 20FA which has Computrance/Absolute enabled. Someone who knows some method to remove it, either a bios patch or some other method ....
                It has caused me a lot of headaches, as much as I try I can not disable it , I have already tried reprogramming the bios, deleting all the chip leaving it blank and reinstalling the original bios from scratch but it does not work, still appears the computrance lock when I enter the BIOS.
                I don't have exactly the original bios of my computer, because when I made a backup it didn't allow it, but I found the following bios which worked perfectly, anyway I can update it with a booted unit:
                Thanks in advance....
                • volinakis
                  • Jan 2021
                  • 2610
                  • N/A
                  #48
                  well, post that "bios which worked perfectly" along with serial no. of your laptop.
                  • JSanthony
                    • Feb 2025
                    • 5
                    • México
                    #49
                    This is my actual BIOS
                    • JSanthony
                      • Feb 2025
                      • 5
                      • México
                      #50
                      My serial no: PC0DSEX5
                      • JSanthony
                        • Feb 2025
                        • 5
                        • México
                        #51
                        Ready, I uploaded the bios that I have and my serial number ....
                        If you need any other information, tell me and I will give it to you.
                        Thank you very much​
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1153
                          • France
                          #52
                          why are you giving us the same file as here?? where is the original??
                          Click image for larger version  Name:	image.png Views:	0 Size:	29.5 KB ID:	3563553
                          https://www.badcaps.net/forum/troubl...88#post1561088
                          in addition you send me messages directly when you didn't even have a post here and a presentation
                          Click image for larger version  Name:	image.png Views:	0 Size:	38.1 KB ID:	3563555
                          • JSanthony
                            • Feb 2025
                            • 5
                            • México
                            #53
                            An apology, I downloaded several bin files from this site, because as I said I do not have an original bios of my laptop, so I could not make a backup and downloaded some from here and in fact the 2 that Brontobyte uploaded worked for me. At first I was going to upload the first one that he uploaded but as you mentioned that it was corrupted then I uploaded the second one, because when I saw that it said that it was the original one I assumed that there would be no problem... as I said, I am a little desperate and I do not have my folders well organized, an apology.
                            Attached is another bios that also worked for me:
                            And an apology, I am new to this site and do not know well how things work here, so I sent you message first as I saw that you were the one who helped the user of the image.​
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1153
                              • France
                              #54
                              put a password and use the patch, Computrace should disappear
                              • sarltap
                                • Apr 2016
                                • 89
                                • algerie
                                #55
                                t460s type 20FA COMPUTRASS help me
                                • peste
                                  • Dec 2016
                                  • 12226
                                  • ROMANIA
                                  #56
                                  post S/N, motherboard model, etc.
                                  • sarltap
                                    • Apr 2016
                                    • 89
                                    • algerie
                                    #57
                                    sn PC-0F1KFW 16/08
                                    • danito
                                      • Jun 2016
                                      • 842
                                      • Romania
                                      #58
                                      Originally posted by sLs112
                                      Hi. Please help me to unlock my bios.
                                      Lenovo Thinkpad T490s type 20NX-002QUK
                                      mb model: FT391/FX390 NM-B891 Rev: 2.0
                                      Thank you.
                                      is for t460s
                                      • Simon16
                                        THINKPAD T460S TYPE 20FA-S1VJ02 s/n: PC-0ET81R - need bios
                                        by Simon16
                                        Please, I need bios bin file for LENOVO THINKPAD T460S TYPE 20FA-S1VJ02 s/n: PC-0ET81R
                                        The bios chip is: W25Q128FV
                                        Attached original bin file
                                        Thanks in avance...
                                        11-25-2022, 03:49 AM
                                        Lenovo ThinkPad T460s Grade T1A Notebook T Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad T460s Grade T1A Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T460s Grade T1A boardview and T460s Grade T1A schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 08:47 AM
                                        Lenovo ThinkPad T460s Ultrabook T Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad T460s Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T460s boardview and T460s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                        09-06-2024, 06:38 AM
                                        09-06-2024, 06:34 AM
                                        Lenovo ThinkPad T460s Notebook T Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad T460s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T460s boardview and T460s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                        09-06-2024, 06:17 AM
