thank you I received the file (outimage) I programmed it on the T460s I have a black screen the keyboard turns on and off the POWER button remains on but nothing on the screen, I tried to disconnect and reconnect it does not change anything.
ThinkPad t460s Patched Bios Request
Re: ThinkPad t460s Patched Bios Request! 20FA
thank you I received the file (outimage) I programmed it on the T460s I have a black screen the keyboard turns on and off the POWER button remains on but nothing on the screen, I tried to disconnect and reconnect it does not change anything. -
t460s i need patched file for my device
hi t460s i need patched file for my device.
I tried the patch file in the forum but it does 2x 5 beeps and closes and there is no image.
My original encrypted dump is here.
model : 20F9Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: t460s i need patched file for my device
BIOS guides, methods, resources and tools
Password removal by laptop brand
LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
help me my friend i need patch t460s this my old dumpsAttached Filesif you find these attachements useful please consider making a small donation to the site
okAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello, could you help me clean the ME region?
My laptop does NOT have the common motherboard which is REV 3.0 or 4.0.
This is REV 0.3 and in the ME Analyzer in the Chipset section it shows me SPT/KBP-LP B
TYPE: 20F9-Z17DUS
S/N: PC-04F278
Thank you
Help me pls
Your problem is that no CSE Me was found in the database.
Version 11.0.0.1151 Corporate LP dose not exist.Attached Filesif you find these attachements useful please consider making a small donation to the site
There's no need to be exactly this version, use any available 11.0.X.XXXX Corporate LP version. Only major and minor version must be the same, hotfix and build number can be different - it's not a problem.
Example: AA.B.C.DDDD
AA - major version
B - minor version
C - hotfix
DDDD - build number
Edit:
Intel CSME (Converged Security Management Engine) Repository download link.
Yes, if you mean Vesko356 it's not a problem, I was just surprised that I
couldn't find the version.
He can try if he wants.
Maybe it will help him.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello Max.
Tried downloading the file but winRar says it's corrupt(
I am trying to find BIOS for Lenovo T460s BT460 U60 motherboard and Winbond W25Q128 chip. Tried a bunch of versions but no luck so far but no luck. Can you please have a look st this one?
Thanks!Attached Filesif you find these attachements useful please consider making a small donation to the site
Read the rules before posting:
Thinkpad T460s
Type 20FA-S03E06
S/N PC0L6ZCM
Would someone please be able to look at this BIOS? The machine works fine but takes 15 seconds to POST and the MEI Version is blank in BIOS. Intel ME will not install. I had used lenovo auto-patcher to remove supervisor password. That worked and I have since updated the BIOS to the latest version. Thanks in advance.Attached Filesif you find these attachements useful please consider making a small donation to the site
I tried to delete password on my Lenovo T460s machine.
Everything was OK (STEP 1 to STEP 7) until I restore original BIOS.
Laptop did not power on, just ​5 beeps and 5 beeps again.
Tried to flash the patched BIOS back - laptop power on, but not possible to boot / open BIOS.
Flashed back original file and 5 beeps again..
Should anyone please check what I did wrong?
Both bios included.
Thank you very much.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thread merged. Please read the updated rules,you must post the laptop serial number - https://www.badcaps.net/forum/troubl...before-posting
I'm sorry, I will do it next time.
Anyway, I tried three different BIOS dump from searching here and the thirt one power on my laptop.
So the problem is solved.Comment
T460s NM A421 rev 4.0 with administrator password, any help please, tksAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/forum/troubl...71#post1798371
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Thinkpad T460s, BT460 NM A421 Rev 4.0 (2016-04). Type 20FA-A0V6VA. S/N : PC-0KFYMH 17/03. Any help unlock administrator password, tksAttached Filesif you find these attachements useful please consider making a small donation to the site
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
This specification for the Lenovo ThinkPad T460s Grade T1A Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T460s Grade T1A boardview and T460s Grade T1A schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 08:47 AM
by Simon16Hello,
Please, I need bios bin file for LENOVO THINKPAD T460S TYPE 20FA-S1VJ02 s/n: PC-0ET81R
The bios chip is: W25Q128FV
Attached original bin file
Thanks in avance...-
by MaxonDomkratHi everyone.
I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...-
This specification for the Lenovo ThinkPad T460s Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T460s boardview and T460s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 06:38 AM
- Loading...
