sony vaio SVF15N1C5E bios
  • poweron
    • May 2019
    • 365
    • italy
    hello this sony has difficulty in recognizing the hd in particular ssd, and therefore I can not install w10, I ask if it is possible to load the bios from dos with a bottable key
    thank you
    • 20795
    Re: sony vaio SVF15N1C5E bios
    thank you
    Click on the Assist button,enter bios,set to legacy boot .
    • poweron
      • May 2019
      • 365
      • italy
      I tried but it does not see hdd ssd equally, if I put a mechanical hdd it sees it install w10 but when I restart it it does not find the system
        • 20795
        Post the bios backup .
        • poweron
          • May 2019
          • 365
          • italy
          the backups of the bios can also be done without unsoldering the chip or do I have to unsolder from the main and put in the programmer?
            • 20795
            Desoldering is more reliable, but use a clip if you want to.Make 2 backups ,compare them with a hex editors File-Compare function (gave you a link to HxD in your other thread) ,make sure both are the same ,and look at the backups to make sure theres some code there. An empty file will be all FF ,comparing 2 empty files is not what you want .
            • poweron
              • May 2019
              • 365
              • italy
              Ok ,thank you
              • poweron
                • May 2019
                • 365
                • italy
                this it's the sony bios backup
                  • 20795
                  try this one.
                  6C2000h
                  6CD000h
                  • poweron
                    • May 2019
                    • 365
                    • italy
                    thanks, i try it
                    • poweron
                      • May 2019
                      • 365
                      • italy
                      I can install w10 on mechanical hdd but on ssd, which is now seen, the installation comes to an end but on reboot it says:a disk error occurred
                      • poweron
                        • May 2019
                        • 365
                        • italy
                        the problem could be the cable that connects hdd that I adapted since it was missing, probably the shielding of the tx and rx lines is not good?
                        • poweron
                          • May 2019
                          • 365
                          • italy
                          yes, the problem was in the shielding of the hdd cable, I made the correct connections and now it works perfectly, thanks for your cooperation
                          • solomost
                            • Sep 2021
                            • 39
                            • agadir
                            bios sony vaio SVF15N1C5E
                            hi please i need dump for sony vaio SVF15N1C5E . my ssd d osent detected in bios, w ont boot an external drive, I've tried all the solutions and it didn't work
                            thnk you for help
                            • peste
                              • 12742
                              • ROMANIA
                              Re: bios sony vaio SVF15N1C5E
                              thnk you for help
                              try the bios from post #9... don't forget to make a copy of the original bios before writing the bios chip
                              • solomost
                                • Sep 2021
                                • 39
                                • agadir
                                I tried it and it didn't work for me,mybe I have to replace the BIOS chip
                                • solomost
                                  • Sep 2021
                                  • 39
                                  • agadir
                                  heeeeelp
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11700
                                    i tried it and it didn't work for me,mybe i have to replace the bios chip
                                    svf15n1c5e
                                      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 05:27 AM
                                    • mariukonie
                                      SONY VAIO PCG-711911M VPCEH2H1E advice about updating BIOS to UEFI needed please!
                                      by mariukonie
                                      Hi. I can't upgrade to win11 I think it's because my BIOS is without Secure Boot function. The BIOS version is R0180Z9. Can you please advise if it is possible to upgrade BIOS to UEFI for this laptop. Many thanks....
                                      05-04-2025, 03:18 PM
                                      Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                                      This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • Marco Rada
                                      Need BIOS for board DA0NE7MB6D0 sony vaio pcg-61611u
                                      by Marco Rada
                                      Hola, alguien tiene un archivo para recuperar la bios en esta board DA0NE7MB6D0, la necesito tengo un error de operating system not found, pero tampoco deja ingresar por el assistant a la Bios
                                      Hello, does anyone have a file to recover the BIOS on this DA0NE7MB6D0 board? I need it. I have an error message about operating system not found, but it also won't let me access the BIOS through the assistant.
                                      in English please..
                                      11-27-2024, 11:03 AM
