Dell Latitude 7480 Bios Password
  • samlak
    • Jan 2016
    • 13
    Can any help me remove the Admin Password. suffix is E7A8.
    I have attached the Bios dump. Appreciate your help.
    thanks in advance.
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Dell Latitude 7480 Bios Password
    Here you are Dallas :
    Become a Badcaps supporter
    Thanks to all supporters.​
    • samlak
      • Jan 2016
      • 13
      Thanks a lot, it worked no more password required.
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        • dimasc
          • Aug 2021
          • 9
          • Ukraine
          Re: Dell Latitude 3400 bios password -E7A8
          Help bios password Dell Latitude 7480 , NZYMNH2-E7A8
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Upload your bios backup.
            • dimasc
              • Aug 2021
              • 9
              • Ukraine
              Thanks, while I saw your post, I found a clean BIOS, sewn it up, everything is fine. Suddenly I spread it to someone useful
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                It won't be usable for anyone but you, or at least ME Firmware should be cleaned, if it's sewn properly of course - I haven't inspected it.
                • dimasc
                  • Aug 2021
                  • 9
                  • Ukraine
                  I found it on the Internet, I asked for it, the laptop works. Here is my dump with password
                    • 20412
                    Unusual as there`s no OEM public key hash,no boot guard,no key manifest.Did you flash the bios with all power removed,main battery and CMOS.
                    • dimasc
                      • Aug 2021
                      • 9
                      • Ukraine
                      tomorrow the m2 disk will come to him I will install the system then I will write off exactly about the performance
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        I found a clean BIOS, sewn it up - "прошил"
                        Now I understand what you meant by "sewn it up" - just the process of programming the chip, I thought you put together "by sewing" a new edited bios based on yours, but you didn't really change anything at all, you've just found somewhere some bios and you've simply programmed it into your laptop. I wouldn't say it's a good idea, not at all indeed but you know best.
                        everything is fine.
                        • dimasc
                          • Aug 2021
                          • 9
                          • Ukraine
                          can you fix mine if it doesn't work?
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            Yes, of course.
                            If you want just say so.
                            • dimasc
                              • Aug 2021
                              • 9
                              • Ukraine
                              Yes, of course.
                              If it's not hard to redo mine. Windows installed, everything works except USB Type C and LAN network card. The history of the laptop is unknown, but it's interesting to try, maybe the problem is in the BIOS
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                I told you!
                                Let me guess: Code 10 in Device manager.
                                P.S. Give me some time to prepare the file.
                                P.S.2 Here you are (same version as yours 1.19.0 try & leave feedback):
                                • dimasc
                                  • Aug 2021
                                  • 9
                                  • Ukraine
                                  Thanks on Monday I will change your version and unsubscribe
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    [RU] отпишусь = [ENG] I will respond / I will answer
                                    [ENG] unsubscribe = [RU] отказаться от подписки / прекратить подписку
                                    A small error in the bios leads to Code 10.
                                    A small (Google) translation error leads to a change in the meaning of the sentence.
                                    • dimasc
                                      • Aug 2021
                                      • 9
                                      • Ukraine
                                      I told you!
                                      Great job, everything loads without passwords and errors, you are a wizard
                                      • darekfl
                                        • Oct 2013
                                        • dorset
                                        Hello.
                                        Thank You!
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • jhanra
                                          by jhanra
                                          11-02-2024, 04:19 AM
                                        • ElBock_
                                          Dell Latitude 7480 bios password removal
                                          by ElBock_
                                          I just got my hands on an almost new dell latitude 7480. Issue is that its previous owner didn't give me the bios pasword.
                                          Can you help me unlock it ?
                                          System Number is FKL4SQ2-6FF1. I've already tried https://bios-pw.org/
                                          Thanks !
                                          06-13-2023, 08:42 AM
                                        • anlsmith
                                          Dell Latitude 5430 Bios Password
                                          by anlsmith
                                          I am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
                                          08-31-2024, 08:46 PM
                                        • TripTop
                                          Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                          by TripTop
                                          Hi
                                          i have dell latitude E7270 with following symptoms:
                                          - takes long time to restart.
                                          - sometimes powers on and then off
                                          - sometimes while working it just dies,
                                          From googling online bios clean could possible resolve this?
                                          i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                          As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                          I reinstall...
                                          09-09-2024, 02:05 PM
