Need bios dell latitude 3410 please
  • dspok
    • Jan 2014
    • 553
    • Nepal
    #181
    anybody?
    • MariusC
      • Aug 2024
      • 6
      • Romania
      #182
      I have the same problem with a Dell Latitude 3410, it does not register the service tag, can you help me?
      Service Tag: G1CKC63
      I don't have the original bios​
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        #183
        Originally posted by SMDFlea
        Compare a locked and unlocked bios with a hex editor, its not as difficult as you might think.
        ill try this . If I can also do it
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          #184
          what is the motherboard? is it MOCKINGBIRD-L CML UMA 6L 19746-1 ?
          • MariusC
            • Aug 2024
            • 6
            • Romania
            #185
            Exactly this one
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              #186
              Exactly this one
              Laptop has two chip and flash this two bins
              • MariusC
                • Aug 2024
                • 6
                • Romania
                #187
                thank you, which tool should I use to flash this bin files? I tried with a bootable stick and from the bios update device option and it doesn't work.
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  #188
                  Oh dont flash any bin I though you have take the board out and use a spi bios programmer,
                  • MariusC
                    • Aug 2024
                    • 6
                    • Romania
                    #189
                    no, i don't have a programmer
                    • MariusC
                      • Aug 2024
                      • 6
                      • Romania
                      #190
                      can it be solved without a programmer?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11809
                        #191
                        Impossible.
                        You can refer to model CH341A (this is the cheapest model). Learn how to use it via Youtube.​
                        • kingaarbi
                          • Apr 2016
                          • 117
                          • Malaysia
                          #192
                          Dell latitude 3410 .With Original Bios No Power.. i Already Tried Other Bins Than it Can't Save The Service Tag.
                          Rebuild Please
                          BN 19746-1
                          ST: 2TNY103
                          • rex98
                            • Feb 2023
                            • 1280
                            • Mandaue CEBU, Philippines
                            #193
                            Rebuild Please
                            BN 19746-1
                            ST: 2TNY103
                            use my post number161 flash both. https://www.badcaps.net/forum/troubl...92#post3252592
                            • kingaarbi
                              • Apr 2016
                              • 117
                              • Malaysia
                              #194
                              Originally posted by rex98
                              Thanks Sir .. It worked Perfectly..
                              • dspok
                                • Jan 2014
                                • 553
                                • Nepal
                                #195
                                Finally it worked.
                                Earilier I already flashed each and every dumps via SVOD3 but it didn't work. Even this dump. And today I flashed with RT809F, it worked. Don't know logic behind this, maybe SOVD3 error in my case.
                                • wahabmahmood48
                                  • Jan 2023
                                  • 12
                                  • Pakistan
                                  #196
                                  i try meany bios but laptop stuck on dell logo DELL 3410 ST:JH6N563
                                  • sudharshan
                                    • Nov 2013
                                    • india
                                    #197
                                    Need bios dell latitude 3410 19746-1 ST: 5VBKB63
                                    • beast4ever
                                      • Feb 2015
                                      • 162
                                      • egypt
                                      #198
                                      I need to clean my password guys
                                      ST: J19G203
                                      EX: 41435196195
                                      • rex98
                                        • Feb 2023
                                        • 1280
                                        #199
                                        ST: J19G203
                                        EX: 41435196195
                                        1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode
                                        • Luis Fernando Tellez
                                          • 8
                                          • Bolivia
                                          #200
                                          consultation forum, I have 3 dell 3410, At first several days ago I programmed to remove the absolute. and it didn't turn on anymore explain the problem (it's like a little flash when the energy, 2 very short white LED flashes and it doesn't do anything or heat up) 2 recover the previous bios (the same) 3 I left the device stored for a few days (and suddenly when I connected it) it worked 4 load another released bios (failure) and it stayed flashing) 5 I react after weeks saved .... Now I did the same with another 3510 (i7 program directly disconnected battery and battery) and it worked Try again with another i5 10ma. and I have the same blinking error change the chips from i7 to i5 but it's the same any suggestion
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                            DELL Latitude 3410 Notebook 3000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 3410 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3410 boardview and 3410 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3410...
                                            09-06-2024, 08:40 PM
