ideapad 3-14iml05 bios GS452 GS552 GS752 NM-C781
  • jogas
    • Oct 2019
    • 17
    • IE
    #41
    On the board:
    GS452
    Rev: 1.0 NS-C781
    2019-11-25​
    Hi
    spins ones and black screen.idisable ram.try all things from here but nothing worked.help needed
    • peste
      • Dec 2016
      • 12868
      • ROMANIA
      #42
      Originally posted by jogas
      On the board:
      GS452
      Rev: 1.0 NS-C781
      2019-11-25​
      Hi
      post the S/N, the full name and model of the laptop, the motherboard model, etc
      • jogas
        • Oct 2019
        • 17
        • IE
        #43
        ideapad 3-14IIL05 Laptop - Type 81WD
        Sn/ PF2JAYTL
        ONBORD Writen this:
        GS454/GS554/GV450/GV550
        REV.1.0 NM-D031
        201901206
        • peste
          • Dec 2016
          • 12868
          • ROMANIA
          #44
          Sn/ PF2JAYTL
          ONBORD Writen this:
          REV.1.0 NM-D031
          201901206
          try post #7..
          https://www.badcaps.net/forum/troubl...os#post1799956
          • jogas
            • Oct 2019
            • 17
            • IE
            #45
            yes i did try all nothing.still black.
            Hi can you help please or sugest something.thanks
            • peste
              • Dec 2016
              • 12868
              • ROMANIA
              #46
              the bios from post #7 is the one from the Lenovo website..it should work..either you wrote the bios with errors..or the laptop has another problem..check the voltages on the bios chip and on the coils..
              • jogas
                • Oct 2019
                • 17
                • IE
                #47
                id did check all voltages.all ok pressit on all coils.only oem bios make spin fan once and gpu and ssd get warm after min or so..other bin files not doing this.try few an nothing. plain black screen.
                • Moalia
                  • Aug 2019
                  • 8
                  • iran
                  #48
                  Hello friends, I wanted the EC file of this model. Thank you for your help
                  gs452/gs552/gs752 nm-c781 rev 1.0
                  2019-11-25​
                  • Moalia
                    • Aug 2019
                    • 8
                    • iran
                    #49
                    ideapad 3-15iml05 bios GS452 GS552 GS752 NM-C781 bios+EC
                    Hello, I wanted the same BIOS file model without graphics. Thank you for your guidance
                      SMDFlea commented
                      Editing a comment
                      If its DIS to UMA look for a hardware solution, the bios can`t be edited. There is no seperate UMA bios.
                    • 21002
                    2019-11-25​
                    EC ,extracted from the bios at post 9.
                    • Moalia
                      • Aug 2019
                      • 8
                      • iran
                      #51
                      thank you very much
                      • Mahesa09
                        • Nov 2021
                        • 63
                        • jakarta
                        #52
                        I have a problem with the laptop not showing up, I've tried bios d post 9 but when the SSD is installed the laptop doesn't show up
                        ideapad 3 14lml05
                        sn PF3A5K23​
                        • Peperoni23
                          • Oct 2016
                          • 27
                          • Philippines
                          #53
                          this is no display with black screen i think this is bios issue . please clean or repair bios or try to clean with no ram on bios this is original bios
                          when i power on there black display
                          post merged...
                          • peste
                            • Dec 2016
                            • 12868
                            • ROMANIA
                            #54
                            post S/N, TYPE,etc.
                            • Peperoni23
                              • Oct 2016
                              • 27
                              • Philippines
                              #55
                              Master this laptop here's no serial number just only part no. On motherboard please type to Lenovo support. P/N - 5B20S44240 . thanks master for support
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11809
                                #56
                                Cannot detect bios without serial number.
                                • peste
                                  • Dec 2016
                                  • 12868
                                  • ROMANIA
                                  #57
                                  look for a label on the case..
                                  • Peperoni23
                                    • Oct 2016
                                    • 27
                                    • Philippines
                                    #58
                                    This master? I can't see s.n
                                    • Peperoni23
                                      • Oct 2016
                                      • 27
                                      • Philippines
                                      #59
                                      My costomer have 2 laptop the second laptop is working I copy bios file from working unit but still no image when I write . The defective motherboard have build-in ram . Did you know master how to disable build in ram?
                                      • misiek_michal
                                        • Sep 2023
                                        • 11
                                        • Poland
                                        #60
                                        Hello. Lenovo Ideapad 3 15IML05 81WB s/n: PF2DQAPN motherboard: NM-C871 rev 1.0
                                        It goes up but there is no image. I'm uploading the original bios. Thank you
                                        Unfortunately, I cannot attach my original bios
