HP Chromebook 11A G8 EE need unlock
  • Taguro-GSMLover
    • Feb 2017
    • 10
    • Soul Society
    #61
    Originally posted by volinakis
    after write new bios reinstall from USB stick made with Chromebook Recovery Utility for your machine.
    its working now sir. Thanks ^_^
    • pixell79
      • Nov 2024
      • 5
      • Serbia
      #62
      Please help me unlock this BIOS file:
      HP Chromebook 11 G8 EE
      ProdID 425DOAV
      S/N# 5CD22634B4
      winbond 25Q128FV (detected by Ch341 Programmer)
      Motherboard model: 0GAH DA00GAMB6I3 REV I
      Thank you
      • ingenieroedu
        • May 2023
        • 78
        • Colombia
        #63
        Hello, help me unlock
        S/N# 5CD04299HG
        Motherboard model: DA00GEMB8C2 REV C​
        • volinakis
          • Jan 2021
          • 2875
          • N/A
          #64
          S/N# 5CD04299HG
          read your bios chipset again, it has no volumes. It means you read it with errors.
          • lint4u
            • Nov 2013
            • 126
            • lint4u
            #65
            ProdID 425DOAV
            S/N# 5CD22634B4
            Thank you
            try this and re-install using USB stick
            • Kevin12111
              • Mar 2019
              • 12
              • Indonesia
              #66
              can someone help to unlock mine ?
              • peste
                • Dec 2016
                • 13803
                • ROMANIA
                #67
                post S/N, full name and model, motherboard model, etc.
                • Kevin12111
                  • Mar 2019
                  • 12
                  • Indonesia
                  #68
                  its working already,thanks for responded,im using rc unlocker
                  • Mekong500
                    • Oct 2024
                    • 22
                    • Poland
                    #69
                    Hi all. Could someone help me to remove enrollment from Hp 11a G8 EE S/N: 5CD019B4TL please? I've tried to modify the file on my own but after reflashing the chip and reinstalling from usb stick, enrollment comes back. I've attached both files, original and modified that I've tried. Thanks
                    • bbcc
                      • Aug 2024
                      • 16
                      • pakistan
                      #70
                      enjoy
                      • Mekong500
                        • Oct 2024
                        • 22
                        • Poland
                        #71
                        It works, thank you very much!
                        • Heaton41
                          • Aug 2024
                          • 5
                          • Algeria
                          #72
                          Hello every one i have problem with hp chromebook 11a g8 ee locked after use the RCUnlock v1.0 i fash it ontheboard without remove the chip the blank chek and verification but the writting work after that i start the laptop i have blinking light on power botton after that i remove the chip from the motherboard when i read it i find not same bios written after that i reprogramme it and it succes with blank and verification but it still blinking power botton plz help me
                          SN:5CD0525TBX
                          PRODID:16W64UT#ABA
                          THANK YOU
                          • som_b1
                            • May 2024
                            • 11
                            • Ukraine
                            #73
                            SN:5CD0525TBX
                            PRODID:16W64UT#ABA
                            THANK YOU
                            Reprogramming the BIOS chip does not help on all Chromebooks
                              • 22159
                              SN:5CD0525TBX
                              PRODID:16W64UT#ABA
                              THANK YOU
                              Unlocked
                              • Heaton41
                                • Aug 2024
                                • 5
                                • Algeria
                                #75
                                Thanks guys for help i will test the new unlock bios and i will repost
                                • arshrao
                                  • Nov 2025
                                  • pakistan
                                  #76
                                  Re: HP Chromebook 11A G8 EE need unlock
                                  your bios is unlocked, you have to reinstall from USB stick made with Chromebook Recovery Utility for your model.
                                  hi i bricked my chromebook by mistake updating wrong bios firmware and now it is not turning on just black screen . plz can u guide me how to fix this
                                  HP Chromebook 11A G8 EE DA00GEMB8C0 REV C
                                  this is my model id
                                  • peste
                                    • Dec 2016
                                    • 13803
                                    • ROMANIA
                                    #77
                                    this is my model id
                                    post S/N, full name and model, motherboard model, ,etc.
                                    post the contents of the bios chip even if it is corrupted..
                                    The bios chip must be unsoldered from the board before writing or reading..
                                    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                    solder wires between the programmer and the bios chip..
                                    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
