MS Surface 5 1796 BIOS
  • choonimar
    • Mar 2020
    • New Zealand
    Landed myself an old Surface 5 but unfortunately it has a system password (UEFI), is this doable without opening screen for bios dump by using flash programming tool?
    I've read through forum with this process is doable with surface 3, but querying about surface 5.
    Thanks in advance
  • FalconPunch
    Surface Pro X 1876 Bios corrupted
    by FalconPunch
    Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
    Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
    08-09-2025, 03:56 AM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • prasath_max
    Microsoft Surface 1796 BIOS Me Clean plz
    by prasath_max
    Hi Guy I Need BIOS For
    Surface 1796
    033792473453
    This Device is Not Booting Windows. Loding Repair Mode and Geting error restaring
    Cannot Access ( BIOS Vol+ and On )
    Here Backup orignal File
    ANYONE CAN GIVE SOLUTION....
    08-25-2024, 04:07 PM
  • cr4zychriss
    by cr4zychriss
    • Rebrand: PC Specialist
    11-14-2025, 04:04 PM
  • muhuruu
    Surface pro 4 bios request
    by muhuruu
    Hey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
    01-22-2024, 05:38 AM
