HP 15-BS CSL50-CSL52 LA-E801P Rev:2.0 Bios
  • shabbir.asas
    • Oct 2018
    • 82
    • kuwait
    Re: Hp 15-bs015la
    hii sir
    u have csl50/csl52 la-e801p bios
    hp 15-bs041ne
    its urgent
      • 20973
      Re: Hp 15-bs015la
      Originally posted by shabbir.asas
      hii sir
      hp 15-bs041ne
      its urgent
      Try the one at post #3
      • saja2441
        • Feb 2015
        • uae
        Re: need Bios dump and ec for hp 15-bs019nk LA-E801P Rev 2.0
        Originally posted by peste
        try..
        thanku
        • lrservicios
          • May 2016
          • 129
          • españa
          Re: csl 50/csl 52 la-e801p bios dump
          Hi everyone !!
          For all looking for this:
          • aboalshood
            • Feb 2015
            • 9
            • hara
            thanks
            • jeewantha
              • Nov 2016
              • 85
              • Sri Lanka
              #26
              HP 15-BS588TU CSL50-CSL52 LA-E801P Rev:2.0 Bios
              Please I need HP 15-BS588TU bios
              MB : CSL50-CSL52 LA-E801P
              Rev:2.0
              2017-07-18
              • peste
                • Dec 2016
                • 12852
                • ROMANIA
                #27
                Re: HP 15-BS588TU CSL50-CSL52 LA-E801P Rev:2.0 Bios
                Rev:2.0
                2017-07-18
                post the bios backup.
                • jeewantha
                  • Nov 2016
                  • 85
                  • Sri Lanka
                  #28
                  backup here
                  • peste
                    • Dec 2016
                    • 12852
                    • ROMANIA
                    #29
                    backup here
                    iit's empty ... try again
                    • jeewantha
                      • Nov 2016
                      • 85
                      • Sri Lanka
                      #30
                      Again I read that IC.
                      But same result.
                        • 20973
                        But same result.
                        Are you using a CH341A programmer
                        • jeewantha
                          • Nov 2016
                          • 85
                          • Sri Lanka
                          #32
                          yes
                            • 20973
                            yes
                            Try it with this alternative software. Make 2 backups and check if both dumps are the same,that way you know if you got a good read, use a hex editors File compare option, or some other method.If you`re using a sop8 clip then attach the charger to the board before making a backup.
                            https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
                            https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
                            • jeewantha
                              • Nov 2016
                              • 85
                              • Sri Lanka
                              #34
                              Thanks.
                              I will try and post result.
                              • jeewantha
                                • Nov 2016
                                • 85
                                • Sri Lanka
                                #35
                                any way to get bios.bin file from bios.exe file
                                https://support.hp.com/lt-en/drivers...A&ssfFlag=true
                                  • 20973
                                  You can run the exe and make a USB recovery key (try it first) ,or copy and save the bios. The update is for more than one laptop model and it has 5 different ones. To know which one to use you should check your bios backup for the right BID bios ID / number .If the USB recovery key doesn`t work then post your bios backup. Your DMI info (serial number,feature byte,windows key) can be copied from your bios backup to the new bios easily using a hex editor.
                                  • jeewantha
                                    • Nov 2016
                                    • 85
                                    • Sri Lanka
                                    #37
                                    USB recovery key not success. now problem is chip damage while I am trying.
                                    before it can read and after save read copy, nothing in saved file.
                                    please may I know to,way for get Bios file without old backup.
                                    • Claudiomfa
                                      • Nov 2015
                                      • 455
                                      • Portugal
                                      #38
                                      Try... one of them it's for your laptop
                                      • jeewantha
                                        • Nov 2016
                                        • 85
                                        • Sri Lanka
                                        #39
                                        08328.bin is working for my board.
                                        No power on with all other files.
                                        but display not working.
                                        • jeewantha
                                          • Nov 2016
                                          • 85
                                          • Sri Lanka
                                          #40
                                          I want to clean this file
                                          Rev:2.0
                                          2017-07-18
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
