Hi,please help bios lenovo y500 model 9541
  • spurki
    • Apr 2020
    • 43
    • romania
    Hi friends,i need bios for lenovo ideapad y500 model 9541
    S/N = YB00400172
    P/N = 59351968
    MO : YB030661518
    Factory id : JVHFC1
    I put this specifications maybe someone have a good bios for this model...i know that it is thread with lenovo y500 but that bios is not ok with my laptop... it power on but sometimes not power off and if i shut down manualy , when power on,just lights it is on but no image...so if someone have bios for this please help,even the EC i want ...the EC and Bios bin...thanks
    • 21002
    Re: Hi,please help bios lenovo y500 model 9541
    Post your backups
    • spurki
      • Apr 2020
      • 43
      • romania
      I don't have backups..laptop was not running when i receive it...
        • 21002
        Did you mak backups of the 2 bios chips before you tried the ones you mentioned in your 1st post
        • spurki
          • Apr 2020
          • 43
          • romania
          No friend..unfortunately no...😞 the laptop was not working...and i don't make backup of that bios...my mistake...i didn't know for sure that after i will put new bin will work..now it is working but with the problems that i mentioned..
            • 21002
            try these .These are virgin bios extracted from the lenovo update, with the DMI + win key from a bios in another thread.I added your serial.
            • spurki
              • Apr 2020
              • 43
              • romania
              Thank you,i will try and post the result..first if the laptop turn on and then after a few days to let you know if my old problem still persist or will be solved.Thank you for now!!
              • spurki
                • Apr 2020
                • 43
                • romania
                Sorry friend not working with ...power but no display img
                  • 21002
                  You won`t get a better bios than the virgin one, the problem is somewhere else. If you want further help with it then start a new thread in the main forum https://www.badcaps.net/forum/forumdisplay.php?f=23
                  • spurki
                    • Apr 2020
                    • 43
                    • romania
                    With other bios working power on and image...but i told you i have some isues...anyway thanks!!
                    • lucaszmn
                      by lucaszmn
                      Problem:
                      Initial Findings:
                      • I concluded that the
                      08-12-2025, 03:01 PM
                    • jendkkd jeje
                      Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                      by jendkkd jeje
                      So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                      I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                      10-11-2024, 03:12 PM
                    • abhorsen
                      Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                      by abhorsen
                      Hey guys,
                      Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                      Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                      Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                      07-06-2023, 10:22 AM
                    • akwky
                      by akwky
                      Hi!
                      04-14-2025, 01:56 PM
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
