acer nitro an515-43
  • Anethra
    • Dec 2018
    • 70
    • Turkey
    acer nitro an515-43
    i have a acer laptop with no screen. im using tl866 and this device cant read xmc qu64 bios chip. so i tryed with another 64fw bios chip with original site bios but not screen, maybe i edited wrong. anyway i need that bios anyone can help me about that? motherboard = ph50q la-j621p rev1.0
    • 21960
    Re: acer nitro an515-43
    Select MX25U6435F ,you can untick Check-ID ,its 1.8V isn`t it ? .Post your bios backup .
    • Anethra
      • Dec 2018
      • 70
      • Turkey
      old bios here thank you
      • Anethra
        • Dec 2018
        • 70
        • Turkey
        can you help me please
          • 21960
          here you go ,extracted from latest bios update + your DMI .
          D 2B0000 - 2B0FFF
          • Anethra
            • Dec 2018
            • 70
            • Turkey
            ty for bios but no screen. i think problem is not about to bios.
            • salawayon
              • Nov 2012
              • 578
              • philippines
              D 2B0000 - 2B0FFF
              got same unit with no display problem but my EC file is at 1mb. i attached my backup. thanks.
                • 21960
                Its the VGA bios youve posted. It might help others anyway
                • salawayon
                  • Nov 2012
                  • 578
                  • philippines
                  thanks. you have a VGA bios for that?
                    • 21960
                    no i don`t ,only what you posted.
                    • jimore
                      • Nov 2020
                      • 179
                      • mexico
                      Originally posted by anethra
                      i have a acer laptop with no screen. Im using tl866 and this device cant read xmc qu64 bios chip. So i tryed with another 64fw bios chip with original site bios but not screen, maybe i edited wrong. Anyway i need that bios anyone can help me about that? Motherboard = ph50q la-j621p rev1.0
                      here my back up try
                      • jimore
                        • Nov 2020
                        • 179
                        • mexico
                        Originally posted by jimore
                        here my back up try
                        my back up
                        • genai
                          • May 2015
                          • 14
                          • hungary
                          Hi, I have a FH50Q LA-J621P Rev 1.0 motherboard.
                          When I turn on the laptop, looks fine , but no picture at all. I downloaded the bios bin and write in the bios chip(25lb64csig) but after I turn on only once give me the "ACER" logo but nothing else.
                          • lapfix
                            • Mar 2020
                            • 2765
                            • my workshop
                            did you do a clear me , if not try or post your old dump
                            • genai
                              • May 2015
                              • 14
                              • hungary
                              When I first read the chip, it was empty. I using a TL866II plus programmer, and xgpro program. I attached a BIOS, what I used.
                              • lapfix
                                • Mar 2020
                                • 2765
                                • my workshop
                                so ,you don t have the original bios !! post your serial number
                                • genai
                                  • May 2015
                                  • 14
                                  • hungary
                                  Sn:nhq6neu00p952110873400
                                  And when I tried to write the chip if I check in( Verify after) I get this message, but without the verify, the program show the programming succesful.
                                  • lapfix
                                    • Mar 2020
                                    • 2765
                                    • my workshop
                                    Try
                                    • genai
                                      • May 2015
                                      • 14
                                      • hungary
                                      Not working.(Turning on but no picture), is it possible because of the programmer not verifying the writing and cause the problem? How can I solve that problem?
                                        • 21960
                                        Clean the solder from the pins using some flux and braid,and make sure the pins all line up in or on the socket or adapter.If you have a spring loaded adapter try pulling up at both sides with one hand and try programming again.If you still have the same errors then the chip is bad,replace with another.
