acer nitro an515-43
  • TuxTaunk
    replied
    hello guys, i have a same problem, this its my dump and serial its: NHQ6ZAL0091251928D3400. thanks! bpoard its a fh50q LA-j621p
    commented on 's reply
    Read https://www.badcaps.net/forum/troubl...before-posting ,and type the laptop serial number
  • Zhyro217
    replied
    This is my old dump incase it needs fixing ...
  • Zhyro217
    replied
    need help guy's I have a Nitro AN515-34 (FH50Q LA-J621P Rev 1.0) Someone tried to replaced the lcd but the laptop died, I found out that the SIO was shorted. I replaced it and tried the bios and ec from post #5 but the laptop only gives me 1.025A with fun spin and turns off. I also tried different bios dumps but still the same issue. voltages are all present when the laptop turns ON, Anyone have other opinion on this issue?
  • shiyab
    replied
    Originally posted by alihomee
    i am having same acer model:AN515-43-R3B4.....with serial num is: NHQ6ZSM001022164B73400....all supplies good but no display on screen...orignal file is attached
    hi try this file
  • alihomee
    replied
  • kalilinux25
    replied
    mobo code is:LA-J621P after 3 to 5 seconds notebook turns off....serial num is:NHQ6ZSM0010031057C3400.....i attached my orignal file
    dmi Added
  • alihomee
    replied
    Thread merged.Please make use of the forum search before posting to find related threads where you can post your request.You do not need to start a new thread every time.
    Read the rules, post the serial number/SNID https://www.badcaps.net/forum/troubl...before-posting
  • lorins_core
    replied
    hello to all Badcaps
    I have an Acer Nitro (AN515-43) with no display Problem. fan spin then stop I did all possible basic solutions but still had the same problem. also, I test the voltage on always (5v,3.3v,1.8v) have I think need to flash bios may rebuild or repair the bios bin file,
    here is the mobo prod. name FH50Q LA-J621P REV 1.0
    and the flash file here
  • peste
    replied
    Originally posted by Rokket
    Hi guys i need some help if someone have the same problem on Nitro 5 AN515-43-R2NL ryzen 7 GTX 1650, because my laptop turn on like 2 second and shutdown immediately.
    I allready backup the main and VBIOS IC BIOS and i dont know if its right/not
    SN:NHQ6ZSN0020210E6E3400
    look for a bios chip on the board, look at both sides... and post the content..
  • Rokket
    replied
  • Vesko356
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Provide a BIOS/EC dump if possible (vBIOS​ in your case)
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
  • Rokket
    replied
    Hi guys i need some help if someone has a backup GPU bios for Nitro 5 AN515-43-R2NL ryzen 7 GTX 1650, thank you
  • hoaca388
    replied
    Re: acer nitro an515-43
    Originally posted by rridma
    original bios and my Serial Number (same problem - no display)
    S/N: NHQBCAA001120088623400
    Wrong chip.
  • rridma
    replied
  • hardware1
    replied
    Originally posted by dikmen
    hi
    I need acer nitro an515-43
    Mb: fh50p la-h901p bios
    Upload your Original Bios and write your device Serial Number.
  • dikmen
    replied
    hi
  • genai
    replied
    I got the new chip, but the problem is a same.
  • genai
    replied
    I got new chip but the problem is the same.
