Afuwin backup problem
  • Guilty_2121
    • Jan 2021
    • 43
    • Türkiye
    hello everyone, I have a msi b450 tomahawk. I can fully dump my bios with afuwin64. but when i try to dump my vestel tab v 1041 2 in 1 tablet bios. I get a half dump.
    Why i need this dump? : I have one more with broken bios.
    Why phsically i don't try to get dump? : Because my ch341a clip doesn't fit so i can't read.
    Why i won't solder and try to dump? : I'm not pro, lost one of them, I don't want to lost second one
    I tried to backup bios toolkit and same problem.
    Please help
    • 22279
    Re: Afuwin backup problem
    You can`t backup the full bios because the flash descriptor will be locked.If you want to backup the full bios you`ll have to desolder it from the board
    • Guilty_2121
      • Jan 2021
      • 43
      • Türkiye
      But why i can fully backup my msi b450 tomahawk bios?
      as I say i'm not pro, I just want to learn
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • cr4zychriss
        by cr4zychriss
        • Rebrand: PC Specialist
        11-14-2025, 04:04 PM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • traxformania
        TONGFANG "GM7TG7P" Bios Password Problem?
        by traxformania
        I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
        But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
        I'm trying to reset my bios without success.
        I tried :
        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
        11-15-2023, 07:32 AM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
