Alienware 13 R2 Bios Request
  • K717
    • Feb 2021
    Looking for an Alienware 13 R2 bios dump - Motherboard LA-C902P
    I have attached the original bios that was extracted from the board if it helps however I believe it's corrupted.
    Thank you!
  • istvanszasz99
    Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
    by istvanszasz99
    Product ID: RZ09-0421
    Motherboard: CH580
    Bios File Size: 32,768 KB
    Dear Forum Readers!
    !!! MY RAZER BLADE...
    11-24-2025, 05:52 PM
  • drux
    Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
    by drux
    I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
    Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
    These models have AMI/Aptio BIOS.
    Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
    11-03-2024, 01:18 AM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • Mr.Ultimate
    Alienware 13R3 bios mod request - to disable dedicated graphics (dgpu failure)
    by Mr.Ultimate
    Hi everyone, hope to get someone to help and modify bios rom for me.
    I need to disable dedicated nvidia graphics chip permanently.
    GPU chip had failed(cracked silicon DIE) and I can only use laptop without failing if I disable nvidia graphics in dev manager (but it still draws power from battery and generates thermal signature.
    Ideally if it was disabled from bios at preboot.
    I believe it is possible, because if I attatch external alienware graphics amplifier , laptop at boot will disable dedicated graphics #1 (failed one) and will only boot with AGA...
    08-06-2024, 05:15 AM
  • zenius
    by zenius
    12-08-2024, 06:13 AM
