Dell Latitude 7310 Bios Password 8FC8
    Re: Dell Latitude 7310 Bios Password 8FC8
    Originally posted by zszahid View Post
    Try this one
    thank you it's worked
      Originally posted by lapfix View Post
      1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode.
      hello , sorry for the delay to responce, i flashed the spi rom and follow the steps it work , thank you to give me your time for help. @lapfix
        Hi guys, I have this laptop but which chip is the bios i need to get to please?
          Hopefully the right one, please remove the password, thank you
            Ready
              Dell 7310
              Admin unlock in bios says 1Y0MBS3-8FC8
              ST: GKBDGB3
              EX: 36056944335
              bios 1.4.1
              asset and ownership tag - none
              manufacture date 01/16/2021
              That is all info from reverse of laptop
              I think I have done this wrong , new post sends me to main forum but i am told to check here first in rules.
              I have ex work Laptop Dell 7310
              Made redundant and it is a year later but it is virtually unusable and total waste atm
              I would like to add a clean Windows but the bios has passwords set on everything it says locked/unlock (if i try to unlock I get that number 1Y0MBS3-8FC8 and a box I need to type into to unlock.
              I am not computer savvy but I feel I am getting somewhere, It has only taken me a year.
              Am I flogging a dead horse?
                Originally posted by aldopc View Post
                Ready
                Sorry for delay had to get another programmer. many thanks works great
                  can you let me know what tool you're using to unlock the dump from an 8FC8 ?
                  thanks
                  ive compared the locked and unlocked files posted here and it looks like the methods vary somewhat
                  ive seen it said that searching for AA within an address range and replacing it with 00 will work but that sounds like a bad idea as im sure AA will appear all over the place
                  or should I just use an unlocked dump and copy my me region from the original locked bios to the unlocked one ?
                    I would also like to know an answer to this
                    If I transplant my bios me region into one of these unlocked files will it work ?
                      nope, you have to perform a clean ME Region to your bios dump.
                      https://www.badcaps.net/forum/showpo...50&postcount=3
                      all donations are welcome,
                        Sorry I didnt read your reply before going ahead
                        I did use one of the unlocked files from this forum and replaced the me region with the one I saved from my locked bios
                        crossed my fingers and switched on the laptop
                        fan was spinning fast with a black screen, after around 1 min ? the laptop rebooted and I was able to enter the bios
                        the first thing it asked was for me to enter the service tag which I did
                        after this I restored bios defaults and rebooted
                        everything is working correctly so far and fan is normal, installing a fresh windows 10 and doing windows updates ... so far no issues
                        did I just get lucky ? it seems to have worked
                          check in Device Manager - System Devices if you have Intel Management Interface, also in Task Manager -Performance if CPU speed is not limited to 0.8GHz
                            in task manager performance the cpu under load is showing 2.79GHz
                            in device manager in system devices I see intel management engine interface working correctly
                              so it'a all ok. but I don't understand why didn't you upload your bios dump here to unlock it, instead doing this kind of way-around.
                                I repair laptops for a living, mostly liquid damaged components
                                sometimes one will come in for a fresh windows/osx installation with a bios password/efi lock and its very rare that the customer will remember what they setup (annoying)
                                for the windows machines I use a java-script master password generator that handles most brands of laptop including dell but doesn't handle 8FC8 and two others
                                I just wanted to do some experimenting with the me region to see if it worked and possibly learn something new
                                but now I'm not sure why this worked as you said that it wouldn't
                                i'll do some more experiments
                                  Hello i got an Latitude 7310 that does not post currently (blinks 3 amber and 6 white)
                                  i don't know if the bios is corrupt or not
                                  and it was locked when it worked
                                  i've tried the usb recovery with no success
                                  Service tag: 816TN73
                                  Board: LA-J261P
                                  Chip: XM25QH256B
                                  Sorry if i posted in the wrong part of the forum
                                    Board: LA-J261P
                                    Chip: XM25QH256B
                                    Try this file ...
                                      Originally posted by Markus1741 View Post
                                      Try this file ...
                                      Thanks got it working after i got a battery for the laptop then i could do usb recovery but i don't know if i screwed up with the service tag thing i exited manufactering mode at 1st boot then got into the bios and entered the service tag there, everything seems to work fine right now and no password on bios
                                        Hello i need Dell Latitude 7310 bios pass.
                                        Service Tag: 94BMQ73
                                        Thank you
                                          Thank you
                                          AAAAAAAA
                                          Become a Badcaps supporter
                                          Thanks to all supporters.
