Need Bios hp x360 gale 4g mb 17887-1a
  • mferna14
    • Jun 2018
    • 1050
    Hi, Does anyone have the BIN Files for this HP ENVY X360 Gale 4G MB 17887-1A Code 448.0ED09.001A (Hp ENVY X360 15-cn0008ca)... The problem., is totally dead.. No light on the DC-in jack when AC Charger plugged in. I am posting the original BIN files, please clean & rectify. BIOS Chipset is MX25L12805D. Help will be greatly appreciated. Thanks
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: HP ENVY X360 Gale 4G MB 17887-1A
    Try and give feedback
    • mferna14
      • Jun 2018
      • 1050
      Sure, will try this tomorrow, & give the feedback. Thanks very much in advance
      • mferna14
        • Jun 2018
        • 1050
        I re-programmed the BIOS chip, soldered, no luck.. not working. I get voltages on the the BIOS 3.3v & the power switch too, but am missing the 3.3v on PS ID centre pin... Any schematic for this model please. Thanks
          • 22289
          Schematic requests go here: https://www.badcaps.net/forum/forumdisplay.php?f=41
          • EfrainHuaconC
            • Aug 2020
            • Ecuador
            I have the same problem, you were able to repair the equipment. If so, could you please share with me what process you followed beforehand, I would appreciate it.
            • gigasi
              • 98
              • Argentina
              Hello, I need the ec and bios of this notebok, I leave my original dump. the equipment turns on but does not emit a video signal and the coolers remain working at 100%.
              • peste
                • 13924
                • ROMANIA
                Re: Need Bios hp x360 gale 4g mb 17887-1a
                try..
                • gigasi
                  • 98
                  • Argentina
                  Originally posted by peste
                  try..
                  does the same. it turns on and off several times and then stays on with the coolers at 100% without video. I have the svod3 but I can't find the mother in the database for the piout. to raise the ecbios
                  tnx
                    • 22289
                    Try this 16MB virgin bios extracted from sp111625 + your DMI .
                    15m-cn0012dx
                    • meroo2041
                      • Nov 2020
                      • 29
                      • saudi arabia
                      Hp envy x360
                      hi every one i have hp envy model 15-cn0000nx board number Gale 4G MB 17887-1A need bios bin this is original file it no display
                      • peste
                        • 13924
                        • ROMANIA
                        Re: Hp envy x360
                        bios extracted from the HP site update.
                        DMI + KEYWIN 720000-72103F
                        • meroo2041
                          • Nov 2020
                          • 29
                          • saudi arabia
                          Re: Hp envy x360
                          thank you for your help i flash it but same problem capsLK flashing 5 time then 3 time
                          • peste
                            • 13924
                            • ROMANIA
                            Re: Hp envy x360
                            you have another problem..remove all the accessories from the laptop (DVD, wifi card, HDD, RAM, etc), check the voltages to be correct ..
                            • dahnking
                              • Apr 2018
                              • 265
                              • kenya
                              Attached file working tested for
                              HP ENVY X360 15m-cn00mdx, Gale 4G MB 17887-1
                              • mgallo
                                Mike Rooster
                                • Jul 2016
                                • Mexico
                                Hello I have a board with the same symptoms, any help ?
                                thanks in advance
                                • gsmart
                                  • Nov 2015
                                  • italy
                                  Hi every one , Have this board a customer has inverted polarity of battery and as burned pd4302 near battery connector seem to diode, but dont know value and is not schebatics on line, any one know the value of this ?
                                  Thanks a lot .
                                  • mferna14
                                    • Jun 2018
                                    • 1050
                                    I think the battery is 11.55V. Take any donor board & if you say its a diode, just remove the diode for the donor board. I think this might be a Zener or use one of these PDZ5.6B. In all ENVY motherboard this ZENER is used. Try it, will not hurt.
                                    • akbari_808
                                      • Jan 2019
                                      • 20
                                      I have an HP laptop and the motherboard model number is 17887-1A (Gale 4G MB). The laptop is a 15-CN0007NA.
                                      The motherboard is working fine, the only problem is it won't charge the battery. The battery is recognised too, it just won't charge it.
                                      Any ideas or help would be much appreciated.
                                        • 22289
                                        thanks in advance
                                        Thanks a lot .
                                        Originally posted by akbari_808
                                        This is the "BIOS Requests ONLY!" sub forum.Start a new thread here for help -> https://www.badcaps.net/forum/forumdisplay.php?f=23
                                        • whelanm87
                                          🛠 Request: Verified BIOS + EC Dumps for HP Envy x360 15-fe0053dx (JPR50 LA-M794P Rev 1.0)
                                          by whelanm87
                                          I’m working on a non-booting HP Envy x360 2-in-1 laptop and need verified firmware dumps for both the main BIOS and EC chip. I’ll be posting my own backups for reference and comparison.
                                          🔍 System Details
                                          • Model: HP Envy x360 15-fe0053dx
                                          • Product Number: 7HVO3UA#ABA
                                          • Build ID: 23WW2GQZ6D
                                          • Motherboard: JPR50 LA-M794P Rev: 1.0 (2023-03-03)
                                          • Motherboard SPS: N30979-ABA
                                          • LCD SPS: N49271-601
                                          • Date Code: 172380
                                          • Keyboard Type: 0
                                          • Feature Byte:
                                            3XeB7kN7.Ba.aqewkwBiBVuhcbdxYPgB
                                            hZnp.praepq0Md4qkdf
                                          🔧 Chip Info
                                          • Main BIOS chip: Winbond W25Q128JVSQ
                                          11-16-2025, 05:26 PM
                                          HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                          This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 12:18 PM
                                          HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-06-2024, 11:17 AM
                                          HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert15-dr1013na 7PW22EA boardview and ENVY x360 Convert15-dr1013na 7PW22EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          HP ENVY x360 ENVY x360 15-cn0755nd Notebook Specification for Upgrade or Repair
                                          This specification for the HP ENVY x360 ENVY x360 15-cn0755nd Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 15-cn0755nd boardview and ENVY x360 15-cn0755nd schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 06:51 AM
