hello everyone i'm a home user and i need my samsung np270e5e-x06tr (Ba41-02243a) bios dump.
					Ba41-02243a bios dump
	Tags: None
Every donation made will go towards server fees and maintenance costs. -
Re: Ba41-02243a bios dump
backup bios -intel cpu and nvidia gpuAttached FilesLast edited by Guilty_2121; 02-28-2021, 06:56 AM.Comment
Every donation made will go towards server fees and maintenance costs.Comment
I'm a home user and i only have ch341a and desolder bios chip. It's a winbond 25q64cvsiq.
I try to read it with ch341a promram versions and they didn't read the chip so i tried colibri program. That's what i get.
I try the bios in this thread (2nd bios). Same problem 1 second fan spins and led blink thats it.
https://www.badcaps.net/forum/showth...ghlight=np270eLast edited by Guilty_2121; 02-28-2021, 08:30 AM.Comment
make sure the chip is soldered or inserted into your adapter ok. Try NeoProgrammer,and AsProgrammer software , if all backups are the same then the chip is bad .
EDIT: Post your backups from both tries
https://www.badcaps.net/forum/showpo...04&postcount=7
https://www.badcaps.net/forum/showpo...6&postcount=10
.Last edited by SMDFlea; 02-28-2021, 08:47 AM.Comment
I think this time i made it correct with neo and as. they both 8mb. thank you for neoprogrammer and asprogrammer.make sure the chip is soldered or inserted into your adapter ok. Try NeoProgrammer,and AsProgrammer software , if all backups are the same then the chip is bad .
.Last edited by Guilty_2121; 02-28-2021, 09:10 AM.Comment
The backup is ok. Whats the history of the laptop as the model number and bios version don`t match,it might have been flashed with the wrong one.
Can you double check that the board number is Ba41-02243a
EDIT: Try this bios - https://www.badcaps.net/forum/showpo...15&postcount=9
.Last edited by SMDFlea; 02-28-2021, 09:25 AM.Comment
my motherboard is Ba41-02243a and on the other side is says lampard_n14x rev 1.0.
I'm sure my laptop is samsung np270 but rest of the number is deleted in times. I found a paper on my hdd and it says np270e5e-x06tr.
History is my little brother hit it with a ball and it fall from the table. Screen broken, after take the screen off. i tried to use with a montitor and it was just start for 1 seceond fans spins, light blinks and that it.
After that bios my motherboard is not responding and have a green light on charging(there is no battery) but it's so weak.
and i don't have 5v in usbs anymore. i think i should go back to my bios ?Last edited by Guilty_2121; 02-28-2021, 11:00 AM.Comment
Its up to you if you want to try the other bios .The history of the laptop would have been helpful in your other thread .Comment
ok thank you so much. I think i have a problem on my 5v power rail because this time i have 2v on usbs. if i can find it i can do something.
Thanks for help master.Comment
			by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
							Channel: BIOS Requests ONLY!
			by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
			Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
			by CityminHi all,
S/N : 5RNK9FFT70...-
			by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM - Loading...
