lenovo ideapad 700-15ISK bios repair needed
Does anyone know what the problem may be ?
lenovo ideapad 700-15isk , when the charger is connected the power indicator lights up and fans spin for a couple of seconds and turn off , the light is still on , and the power button does nothing and the chipset heats up, i have flashed the bios images that were given in this thread and it has done nothing, any suggestions ?
Motherboard model: LOL SKL MB
15221-1
448.06r01.0011
Bios chip: MXIC MX 25L12873FLeave a comment:
I will explain to you how I had this problem I wanted to do the online update of my LENOVO IDEAPAD 17ISK laptop, the update went well and when restarting the screen remained black, the fan turns normally but impossible to restart it normally. I pressed the reset button with a paper clip I enter the bios as you can see in the attached photo, but impossible to restore or do anything else. Thank you for your help
1 PhotoLeave a comment:
Hello
I need bios bin Lenovo ideapad 700-17ISK
Serial number is : R90KYCVG
Thank youLeave a comment:
pls help me Lenovo ideapad 700-15ISK bios repair neededanakart : LOL SKL MB 15221-1448. 06R01.0011
The original bios and ec file is available below. thank you in advanceLeave a comment:
Re: Need help with Lenovo 700-15isk bios
Tried it and it doesnt give any image. It starts up and fans go full speed.
Edit
Screen comes on for a sec and laptop restarts itselfLast edited by GeneralPag; 09-20-2023, 08:57 AM.Leave a comment:
I am trying to clean ME region but Intel FIT wont open the .bin file.
Unable to open file: C:\Flash Image Tool\WIN32\len70015isk.bin. Reverting to default configuration.
Can someone else try to clean me region for me.
Lenovo 700-15isk
LOL SKL MB
15221-1
448.06R01.0011Leave a comment:
Lenovo 700-15isk
LOL SKL MB
15221-1
448.06R01.0011Attached FilesLeave a comment:
Re: lenovo ideapad 700-15ISK bios repair needed
Hello, thank You very much for this forum thread. Helped my laptop work.
I have a questions for You:
Could you tell me what offset should be copied to the new bios in HxD
- copy laptop serial numbers, laptop data. I found (begin offset 00801000 to 008011F0) but i'm not sure its correct part
- windows key
I'm sorry if the question is trivial for you, I just bought the programmer yesterday and after the 5th attempt I managed to restore it to work (black screen). This was done thanks to a batch shared by @peste
Windows key : Find : 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00Leave a comment:
- windows key
I'm sorry if the question is trivial for you, I just bought the programmer yesterday and after the 5th attempt I managed to restore it to work (black screen). This was done thanks to a batch shared by @pesteLeave a comment:
The bios has been tried, there is no problem, but when I say turn it off, the power led does not turn off, it turns off after 3 minutes. Thanks for your interest.Attached FilesLeave a comment:
Re: İdeapad 700-15ISK
yes, the file in the 11th message is already I was able to take an image with it, but after a while I started to get such an error, it may be in ec, my problem, but I can not program ec, it gives an error, let me look a little more thanksLeave a comment:
try..Attached FilesLeave a comment:
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
Channel: BIOS Requests ONLY!
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by Popel1083Hi,
I want to remove the Bios Password of my Lenovo IdeaPad U330p with the Lenovo autopatcher. I have the CH341A Black and I'm using NeoProgrammer. The Programmer has an LED that indecates when it reads or writes the Chip. When I try to Connect my Programmer to the Bios Chip (Winbond 25Q64FVSIQ) the LED lights up even though I didn't click on Detect botton in NeoProgrammer. If i click on Detect the LED still remains on and NeoProgrammer says "IC not responding".
SN: QB08570065
MB: DA0LZ5MB8D0; REV: D; MODEL J31/N02-
- Loading...
