SAMSUNG ba41-01666a need bios to fix
  • String2016
    • Nov 2015
    • 2235
    • philippines
    can someone fix this bios please issue is no display tried with good ram still no display i will try to flash bios can someone fix this file please, attached the original dump.
  • peste
    • Dec 2016
    • 12755
    • ROMANIA
    Re: SAMSUNG ba41-01666a need bios to fix
    try..
    • String2016
      • Nov 2015
      • 2235
      • philippines
      still no display
        • 20818
        still no display
        try this one .
        • String2016
          • Nov 2015
          • 2235
          • philippines
          thanks still same issue maybe this is not bios problem gpu is very cold
            • 20818
            Is the serial number HSHY91AC201572
              • 20818
              After a closer look i think the bios you posted is originally from a NP300E7A.
              Try this one https://www.alisaler.com/samsung-np3...1-01666a-bios/
              • String2016
                • Nov 2015
                • 2235
                • philippines
                @smdflea its working thank you
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                  09-07-2024, 05:50 AM
                • TJ65
                  Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
                  by TJ65
                  i made out of two broken Samsung Galaxy Tabpro S one that works partially.
                  The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
                  I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
                  The problem is, that the micom Version doesn't match with the bios version, see picture.
                  How can i update the Micom Version? The Samsung bios update wont work.
                  With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
                  01-09-2025, 01:35 PM
