MS-16J61 rev:1.0
  • hell
    • Jul 2018
    • 51
    • sultanbeyli
    MS-16J61 rev:1.0
    help MS-16J61 rev:1.0 bios ?
    old bios black screen ?
  • peste
    • 12835
    • ROMANIA
    Re: MS-16J61 rev:1.0
    post the full name and model of the laptop
    • hell
      • Jul 2018
      • 51
      • sultanbeyli
      msi model : gl62 6qc-081xtr
      bainbord model : ms-16j61 rev:1.0
        • 20952
        The full 8MB bios and EC is available direct from the MSI support page -
        https://www.msi.com/Laptop/support/GL62-6QC
        • hell
          • Jul 2018
          • 51
          • sultanbeyli
          There is a black screen event on the device, bios written over bios windows bios tried unfortunately garbage
          • peste
            • 12835
            • ROMANIA
            try..
            • hell
              • Jul 2018
              • 51
              • sultanbeyli
              try..
              Unfortunately, the same black screen, the screen becomes shaky fixed at 41 amps
              • peste
                • 12835
                • ROMANIA
                you have at post # 6 the main bios from the MSI site for this model, enter the MSI site at post # 4 and write the EC bios, you won't find a better one, if it doesn't work you have another problem ..
                • mitchw
                  HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                  by mitchw
                  Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                  After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                  After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                  I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                  04-29-2025, 03:45 PM
                • BlueNitesFire
                  I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
                  by BlueNitesFire
                  So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
                  03-08-2025, 03:49 PM
                • Technodoc
                  ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
                  by Technodoc
                  Asus laptop G614JZ-N3012W Rog Strix with i7
                  Mainboard G634J-PMV-VGT
                  6050A3441302-MB-A01
                  2023-02-10
                  Power button works okay....power light goes on
                  Red "bottom" leds go on
                  Charging led works
                  Fans do not spin, capslock key does nothing, screen stays black
                  I would like to program the bios again, to rule out a corrupted bios.
                  However I run into a size error
                  The bios chip is a Winbond 25R256JVEN
                  Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                  02-24-2025, 04:46 AM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
