Fujitsu ah530 - Bios
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    first you need to flash the EC bios U22 , and see what change and then flash the bios U20,
    this is a working ec and main bios;
    by Vesko356
    08-11-2023, 03:27 AM
  • abhorsen
    Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
    by abhorsen
    Hey guys,
    Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
    Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
    Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
    07-06-2023, 10:22 AM
  • mrrubik
    Dell Optiplex 7010 micro bad BIOS flash?
    by mrrubik
    Hi folks,
    I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
    After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
    Steps I took:
    1. Read BIOS with CH341a, verified hash twice
    2. Patched
    12-23-2024, 04:11 PM
  • AkaBukai
    Is it okay to flash stock bios onto the motherboard's BIOS?
    by AkaBukai
    Hi there,
    I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
    The little LED on the power button is flashing slowly and nothing happen.
    This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
    So I decided to flash the BIOS using a cheap programmer.
    And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
    I also...
    12-19-2024, 12:15 PM
  • James Jackson
    Panasonic CF-20G0247VM BIOS Bad Flash Help
    by James Jackson
    I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
    Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
    05-01-2025, 11:28 AM
