Latitude 5411 bios Password 8FC8 Suffix
    Originally posted by babydoll8867 View Post
    Hi, can you please help me unlock this 5411? st:45102F3 suffix 8fc8? it didn't work with any generator. thanks!
    1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
      Nevermind, I figured it out by comparison, thanks anyways!
        Thank you very much for your effort!
          Hi guys I have Dell Latitude 5411, with service tag: 528J8G3.
          There is a problem with original BIOS there is no display and it is boot looping. I flashed it with a BIOS I found online which I am also attaching but there are two problem in it, 1st it is booting very slowly takes around 5 min. to start and BIOS is password protected which won't allow me change anything in BIOS Setup. Also Another issue is few of my software are HW activated after changing the BIOS they all got unregistered. My priority is to restore the original BIOS if possible , I have been trying to fix this issue for days now without reaching better solution I really need help with this.
          Please check the attached files
          Any help is much appreciated, Thanks
            Try this your file clean me and unlocked
              Hi mate , Sorry for the delay
              Tested it but it is still no display when booting.
                help me unlock Dell 5411
                board number LA-J272P
                S/N 29JJ253
                thanks
                  Sir, please help me to remove bios password of DELL Latitude 5411 having Service Tag: 3L0TZ33 , thanks in advance
                    Please follow this format
                    issue:
                    Model:
                    Serial Number:
                    Motherboard Code:
                    Post your backup bin even its corrupted
                      issue: BIOS Password
                      Model: Dell Latitude 5411
                      Serial Number: 3L0TZ33
                      Motherboard Code: wrong password
                        SMDFlea commented
                        Editing a comment
                        Posts moved to 5411 thread topic. We can`t help unless you post your bios backups.
                      #51
                      Helo
                      Can anyone repair the BIOS?
                      Need remove password 8FC8 and clearME
                      ST: 45BR9C3
                        Originally posted by daro19862 View Post
                        Helo
                        ST: 45BR9C3
                        unlocked and clean me give feedbacks
                          Not work.... power led is on power consumption 0,04A ofc no picture
                          file bin build_work is file from internet.
                          I have orginal BIOS but is interrupt.
                            here try write your st in first boot then alt+f
                              Work all good thanks.
                                Originally posted by lapfix View Post
                                Re: Bios password Dell Latitude 5411
                                There's another bios chip that you must post it
                                Can you give me a tip where is the 32MB Bios Files is Located on the Dell 5411 Mainbaord? I have found one under the M2 SSD but if i read the Bios is only 16MB Filesize. Thank you so much. I attached the Orig Bios File
