Microsoft Surface Book UEFI password removal
  • merulok
    • Jan 2021
    • 7
    Hi guys, can anyone help? I have a UEFI locked Surface Book (original version, model 1703) and I need to get into the BIOS settings to enable the camera but password has been lost.
    I've been reading the threads regarding Surface Pro 3 and 4 and how they differ in UEFI protection - is the Surface Book more like a Pro 3 (where password can be retrieved from a BIOS dump) or a Pro 4 (where it looks at though flashing a new file is needed). Clearly I'd like to fix this without dismantling the screen (as I will break it) - can anyone offer me any help? [Can I re-activate the camera without needing UEFI password?]
  • IVARSX
    • Jan 2022
    • 8
    • Latvia
    Re: Microsoft Surface Book UEFI password removal
    I have a same problem.
    Can't get dump file.
    Showing error:
    Error 316: Protected Range Registers are currently set by BIOS, preventing flash access.
    Please contact the target system BIOS vendor for an option to disable Protected Range Registers.
    FPT Operation Failed.
    What can i do?
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      What command did you use?
      • AAAC
        • Jan 2020
        • 458
        • Mexico
        @IVARSX
        Try opening command prompt as Administrator, then change path and run the utility… you may as well use this other utility in this other post and upload your file.
        https://www.badcaps.net/forum/showpo...&postcount=250
        • IVARSX
          • Jan 2022
          • 8
          • Latvia
          @RethoricalCheese i use FPTw.exe -bios -d biosreg.bin
          @AAAC Yes, i open command prompt as Administrator, then change path and run the utility...
          This other utility showing error: " Can not identify the BIOS ! "
          Maybe Surface Book BIOS can't get bios dump.
          I found another threat of this problem https://www.badcaps.net/forum/showth...t=surface+book
          • IVARSX
            • Jan 2022
            • 8
            • Latvia
            Ok, need ignore error '' can not identify the bios '' and i get file
              • 21467
              There`s more than one version of the Intel CSME System Tools,the newest having an updated fparts.txt file supporting more bios chips.
              • IVARSX
                • Jan 2022
                • 8
                • Latvia
                I make dump file with Universal bios backup toolkit 2.0
                • Moonglum
                  • Jun 2022
                  • United States of America
                  Hi , I have a surface book 2, original version model1703, and it has a bios password on it. I don't have sound, a camera, or a wifi card and I can't get into the bios to make changes , I've read on this sight that I am suppose to do a bios dump but I don't know how or what to do, can someone please help me ?......Thank you very much
                  • iiflkaran
                    • Oct 2023
                    • India
                    I bought a Surface 1703 and BIOS is asking for a password which is unknown by the seller. It is not getting to USB boot mode there is not much choice only a password screen. May I help to get that rid and get it into normal operation?
