HP 840 G7 password
    Originally posted by Vesko356 View Post
    You MUST:
    Thank u I end up using RCUnlocker on the 16mb chip & its good now.
      Vesko356 commented
      Editing a comment
      Good for you. You're welcome.
    Hello friends,
    I have a EliteBook 840 G7 where I flashed the 32mb BIOS chip with HPUnlocker but the password still exists.
    Now I read about unlocking the 16mb chip and also use RCUnlocker.
    I could not find the 16mb chip.
    Anybody have experience with unlocking an 840 G7?
      Vesko356 commented
      Editing a comment
      Thread merged.
      Read the rules before posting
      You MUST:
      • Post under a related thread if it exists
      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    try to find chips like WINBOND - xmc - MXIC - GIGADEVICE - cFeon and backup and attach here...
      Hii
      Need unlock bios password
      Hp elitebook 840 G7
      SN : 5CG1053NYJ
      Bios attached
        Originally posted by Elaid02 View Post
        Hii
        Hp elitebook 840 G7
        SN : 5CG1053NYJ
        Bios attached
        RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
        You MUST:
          Hii
          Hp elitebook 840 G7
          SN : 5CG1053NYJ
          Bios attached
          only flash this EC. do not touch the main.
            Hello, I need help deactivating Absolute. Thank you
            SN:5CG1049713
              Originally posted by rex98
              i cant upload directly.
              first boot reset to factory defaults and exit, 2nd boot reset security settings to defaults.
              use bcu here's you dmi info:
              Serial Number: 5CG1049713
              Product Number: 20V17UC#ABM
              CT Number: PJSCQ00WBERONK
              Description: HP EliteBook 840 G7 Notebook
              build_id: 20WWCMBT601#SABM#DABM
              Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUcAdUdpdqeMfPguhKhkj4jhk8mEmV.tN
              MAC Address: B0-22-7A-72-6C-84
              Thanks, working perfect
                Hello! I received a faulty 840 G7 laptop with two BIOS chips removed. My customer said that the laptop was locked to the company (Windows Autopilot?) Serial: 5CG1364XCT (this number inside the dump matches). I couldn't start the laptop - it blinks 2 times. Probably the original dumps are damaged. I tried different ways of cutting off the dump from the official website, also with replacing the ME region. I also tried flashing both chips from "#298".
                Does anyone have verified service dumps for this model? with which the laptop will definitely start
                  XX
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    Originally posted by hoaca388 View Post
                    XX
                    Thanks for the given file, however it did not work at all. The mainboard behaves faulty as before without any improvement. I tried this dump you sent in pair with my native dump EC, as well as with other EC dumps I could find. No positive result.
                    I would like to ask if this dump you sent launches any mainbord, because in my case the removal of slips by the hub is not executed, as well as the power cores is absent because of this. I would like to be sure that the problem I am facing is not caused by the BiOS dumps pairing.
                      Serial Number:5CG0441QGS
                      Product Number: 24X44UC#UUF
                      XU100259-20079
                      A/S 1588-3003
                      R-R-hpk-HSN-136C-4
                      thank you everyone
                        XU100259-20079
                        A/S 1588-3003
                        R-R-hpk-HSN-136C-4
                        thank you everyone
                        try
                          the password is gone but it show like this please help thank you
                            SWAT Issue please fix
                            XU100259-20079
                            A/S 1588-3003
                            R-R-hpk-HSN-136C-4
                            thank you everyone
                              XU100259-20079
                              A/S 1588-3003
                              R-R-hpk-HSN-136C-4
                              thank you everyone
                              first boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to daults and exit.
                              you can disable permanently the absolute lock in BCU tool.
                              here's your DMI info. use bcu:
                              Serial Number: 5CG0441QGS
                              CT Number: PJSCQ00WBEE0WF
                              build_id: 20WWCMBT601#SUUF#DUUF
                              Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mE.ye
                              MAC Address: 3C-18-A0-7E-31-D9
                                Thank you so much i appreciate it. God Bless team badcaps. Will try!
                                  please help delete module absolute computrace NB hp elitebook 840 g7
                                  sn 5CG0523JYH
                                  SKU 24M80UP#ABA
                                  UUID 2FFD401C6ADE6F41B97F8B6FA2FA706B
                                  UUIDsf 1C40FD2F-DE6A-416F-B97F-8B6FA2FA706B
                                  ASSET TRAKING NUMBER 4420021
                                    Master pls. help me to clean dump file.
                                    SN:5CG0465ZFL
                                    ProdID: 24X44UC#UFF
                                    more thanks master🙏
                                      SN:5CG0465ZFL
                                      ProdID: 24X44UC#UFF
                                      more thanks master🙏
                                      here.
