HP 840 G7 password
    Re: HP 840 G7 password
    Originally posted by alfredposadas09 View Post
    only remove swat lock is it okay for you?
    yes my problem is swat locked bios., but can you clean all dumps so then i can study if it is okay., do you mean that if i need to clean bios password also right?
      Here is your swatlocked removed make sure to reformat ur ssd
        i dont have the solution to open the bios administrator password but I can assure you that this bios now is no more absolute
          no need to open the administrator just flash the main bios beside in ram slot
            i'll try this one brother, feedback later..checked PM bro
              job done swat lock removed,, thanks bro for helping...
                Hello guys, I have a machine with a bios password, which I have tried to remove as described in many posts here. I also tried with the RCUnlocker_v_1_0... unfortunately without success. Can you help me to unlock it? I've attached both BIOS files below.
                  Originally posted by bigpunk View Post
                  hello guys, i have a machine with a bios password, which i have tried to remove as described in many posts here. I also tried with the rcunlocker_v_1_0... Unfortunately without success. Can you help me to unlock it? I've attached both bios files below.
                  here is your unlock file
                    NICE! I have access to the bios again.
                    Is there a way to get rid of the "HP Endpoint Security Controller Problem" message? It appears at every start now.
                      yes send 32mb bios beside in your ram slot
                        Is attached in post #207 (both files)
                          is attached in post #207 (both files)
                          flash it again.. 32mb and my 16mb that i gave you.. U must flash it again
                            You Sir, You are a genius beyond measure! It works flawlessly
                            THANK YOU!
                            btw this time I was too lazy to desolder the eeprom off the board :P
                              great
                                Should I enter values other than the serial number and product ID while the laptop is in program mode?
                                On every restart It counts down from 30 and when it drops to zero I probably won't be able to change anything anymore or will I?
                                  yes manually
                                      Program 16MB chip only, leave the 32MB as is, and consider donating to the forum if you're happy with the result..
                                      Become a Badcaps supporter
                                      Thanks to all supporters.​
                                        please remove swat lock.. thanks
                                          HI!!!
                                          I've attached both files.
                                          Need Admin bios password remove.
                                          I tried RCUnlocker on the 16MB file. (It not boot up to HP logo at all).
                                          Restore the original file, system works but the bios password still there.
                                          Need help.
