Can someone change Serial number, model and uuid in bios?
Lenovo ideapad S510P change SN in bios
Tags: None
Re: Lenovo ideapad S510P change SN in bios
Whats the problem ,do you have a corrupt bios.Are you wanting to swap the DMI from one bios to another. -
Bought used laptop there was on bios and he didnt remember. I flashed bios with ch341a programmer but forgot to make backup. The bios version which i used was different. Now i found same version what was original one for this laptop but its from Ideapad S410P. I want to change it with 510 and with real serial number. (It had windows license and lost it too, i have key which recovered from hdd but cant us it again.)Comment
Post your serial numberComment
Try this one .Attached Filesif you find these attachements useful please consider making a small donation to the site
Windows license works tested on reinstall and not asking for key but serial number is 1 https://prnt.sc/w8l9uhComment
last try .Attached Filesif you find these attachements useful please consider making a small donation to the site
by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... -
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by joven016Problem is blinking power led only
i don't know exactly if it's s145-15igm or s145-14igm
have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
Already tested some of posted bios here
S145-14igm - success but invalid serial and not booting on OS
S145-15igm - success with serial and some other info in bios but still not booting on OS
already tried installing new windows but always booting on bios setup
windows installer flash drive detected on...-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
- Loading...
