A1278 820-3115-B EMC 2554 Bios Password Removal
  • Pigo
    • Nov 2020
    • 8
    Hello.
    I'm doing this myself. I've done some research regarding how to do this. I was hoping that I could get some help from you here.
    I don't have a SMD soldering kit so I bought this programmer:
    SOIC8 SOP8 Flash Chip IC Test Clips Socket Adpter Programmer BIOS + CH341A 24 25 Series EEPROM Flash BIOS USB Programmer Module (Double Clip+ USB)
    I know it can provide 5v or 3v so when it gets here; I hope that it has instructions so I don't send 5v or the wrong voltage on the wrong line; I don't want to kill this chip.
    So far I know that I need a Clean bin, remove the password section by looking for $svg, add my serial number and my hashcode.
    I will be uploading my bad bios bin when I receive the Programmer; it should be here in an hour or two. Any tips, tricks, advice are welcomed.
  • peste
    • Dec 2016
    • 13781
    • ROMANIA
    Re: A1278 820-3115-B EMC 2554 Bios Password Removal
    Originally posted by Pigo
    Hello.
    remove the bios chip from the motherboard before reading or writing it, make a copy of the original bios of the laptop before playing with the bios chip ... search for $svs ...
    • Pigo
      • Nov 2020
      • 8
      I was able to read the chip with the programmer and get a dump of the bad bios. I will leave it attached in the comment.
      I used AsProgrammer.
      SPI option selected.
      IC: N25Q064A
      My board has the chip: 25Q064A
      AsProgrammer doesn't have an option to search.
      • peste
        • Dec 2016
        • 13781
        • ROMANIA
        IC: N25Q064A
        try..
        • Pigo
          • Nov 2020
          • 8
          try..
          The keyboard stopped working and the power button doesn't work now.
          Update:
          I didn't connect the ribbon correctly. The Bios is still locked.
          • Pigo
            • Nov 2020
            • 8
            try..
            It worked but when the installation loads it says: Your computer is disabled. Try again in 60 Minutes.
            Update: It went away after a PRAM, SMC reset.
            • Pigo
              • Nov 2020
              • 8
              try..
              It worked. A thousand thank you's
              • Bizb9l21
                • Jan 2023
                • 26
                • Usa
                MacBook EMC 2554 2012 EFI password.
                Hey all,
                Purchased 4 units of EMC 2554 2012 13" MacBook pros all EFI locked ( guessing from a school) .
                What would be the fastest and easiest way to remove bypass the EFI password?
                I recently purchased the EZP2019+ programer with the clip but heard that it's sometimes not safe to use the clip and in some case the chip need to be removed and I'd like to avoid that .
                Any suggestions?
                Anyone here use the EZP2019+ with the clip that can tell me if I need to inject power externally or not ?
                • Bizb9l21
                  • Jan 2023
                  • 26
                  • Usa
                  Re: MacBook EMC 2554 2012 EFI password.
                  Update:
                  Used clip but only works when the charger is connected to the Mobo , I edited the bin file and replace all the characters between $SVS and replace all with FF .
                  The EFI is unlocked but now GPU shows 3MB and graphics look horrible and slow .
                  Anyone have a unlocked bin file I can use or tell me what you think is wrong ?
                  I saved a copy of the original file .
                  • Bizb9l21
                    • Jan 2023
                    • 26
                    • Usa
                    2nd update:
                    After os install and firmware update gpu is back to 1.5gb and laptop is working good .
                    1 out of 4 of the laptops I'm not able to read and seems like the reason is with my programmer using the clip I can't get the suspend voltage to power the chip .
                    Any suggestions?
                    I would rather not inject voltage and not remove the chip.
                    Otherwise the laptop turns on fine , no issues just EFI locked .
                    I did try thet trick or connecting the pin 4 to ground inside my EZP2019 but didn't work, and I used the same clip and programer to unlock 2 other of the same model , same chip same EMC 2554
                    Thanks ��
                    • peste
                      • Dec 2016
                      • 13781
                      • ROMANIA
                      Originally posted by Bizb9l21
                      2nd update:
                      Any suggestions?
                      Thanks ��
                      try this..
                      stick wires between the programmer and the bios chip, if you can..
                      • Bizb9l21
                        • Jan 2023
                        • 26
                        • Usa
                        Hey @peste , can you please be more specific?
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          try this..
                          stick wires between the ... if you can..
                          ...wires between the legs...
                          Originally posted by Vesko356
                          18+
                          I just couldn't resist
                          Peste, no offense buddy, I'm just joking here.
                          Become a Badcaps supporter
                          Thanks to all supporters.
                          • Bizb9l21
                            • Jan 2023
                            • 26
                            • Usa
                            I am using a clip , should I try to cut the wires in the middle of the clip and inject 3v like that ?
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              I'm just amazed at what "genius" ideas I'm reading through some of the forum posts.
                              • Bizb9l21
                                • Jan 2023
                                • 26
                                • Usa
                                Thanks for your input, very helpful.
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  You're welcome.
                                  I don't know what else you expect me to say about your brilliant ideas.
                                  Maybe it's time for you to think about some good tools. Like an adequate programmer and hot air station for example.
                                  I don't know what kind of results you are expecting from this cheap programmer and a clamp. You would have done the job long ago with the right tools.
                                  • Bizb9l21
                                    • Jan 2023
                                    • 26
                                    • Usa
                                    You're welcome.
                                    It's a shame you that you choose to interact with members in this manner.
                                    Kindness and being polite is free , you can convey your message in many different ways .
                                    I have a hot air station but I was trying to avoid taking the laptops apart and you would have known that if you read my post.
                                    I'm almost never need to unlock SPI chips or flash bios so I don't want to spend money on a programer I will rarely use.
                                    If you have any actual input that would be nice , if not......
                                    • Vesko356
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      I've already told you what you should do, but you obviously have your own views on the matter.
                                      I've always been amazed at people like you, wanting to loosen a tight nut with your bare hands, but fail and then ask if it would help going to the gym to built muscles like Mr. Olympia. Nope, it will not help. It can be done with a wrench.
                                      It has been commented a thousand times that clips are an unreliable method, especially in combination with an unreliable programmer like ch341a and yours. In addition the clips are so poorly made and after being used a few times, the tip is deformed in a way it can be used no more, and with each subsequent use it gets worse and worse. Quite often the ribbon cable gets unsoldered from some of the clips pins because it is thin and poorly made too. So go ahead, cut wires, inject voltages, do whatever you want.
                                      The way you think you can read the chip correctly, and then program it with verification with the available skills and tools is a mystery that no longer concerns me.
                                      • Bizb9l21
                                        • Jan 2023
                                        • 26
                                        • Usa
                                        Ahhh here we go .... Some knowledge transfer .
                                        This is valuable information, now I really thank you for your input.
                                        What's your take on Jtag connectors are they more stable?
                                        What is a good cost effective programer for someone like me that uses it maybe every 6 months?
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
