lenovo nm-c171 S145-14AST S145-15AST
  • ayoub.bouchenni3
    • Nov 2018
    • 34
    • morroco
    #41
    Re: need bios NM - C171 REV 1
    Originally posted by tugrul63
    this is working. problem ok.
    working good thnx
    • borma
      • Jun 2018
      • 4
      • turkiye
      #42
      Re: lenovo nm-c171 S145-14AST S145-15AST
      Thankyou
      • interpc
        • Feb 2015
        • 74
        • Mexico
        #43
        thanks
        • fichamba
          • Dec 2011
          • 132
          • Spain
          #44
          Perfect also for me. Thanks a lot!.
          • Fenixkoa
            • Jul 2022
            • 4
            • Deutschland
            #45
            Re: Lenovo s145-14ast Change SN and factory info
            Originally posted by anshad
            Try..
            This is a bios for another Ideapad 320-15AST model
            Sorry it's my fault, I didn't provide my model.
            mine is the Ideapad s145-15AST
            bois version: AYCN28WW
            • hoaca388
              Badcaps
              • Jan 2022
              • 11809
              #46
              S145-15AST Laptop (ideapad)
              • Fenixkoa
                • Jul 2022
                • 4
                • Deutschland
                #47
                Everything works correctly.
                Thanks for your help guys
                • claudio21s
                  • Nov 2022
                  • 30
                  • chile
                  #48
                  Originally posted by kingaarbi
                  Lenovo NM - C171 REV 1
                  on then off..
                  thanks
                  • O.Szilard
                    • May 2019
                    • 161
                    • hungary
                    #49
                    Thanks, it works for me too!
                    • mANgLEr
                      • Feb 2023
                      • 12
                      • England
                      #50
                      Apologies if I shouldn't post this here, I am a new member and cannot start a thread yet. I'm trying to fix a possibly corrupted BIOS but do not know the exact model I have here.
                      The Lenovo IdeaPad has no useful labels on it apart from 'AMD A4', so I'm going on motherboard silkscreen alone:
                      FS44A&FS54A NM-C171
                      Rev:1.0
                      2019-01-02
                      The BIOS chip is a 8MB W25Q64FW 1.8v SOIC8 that reads okay in a T566 programmer, so I have the BIOS extracted. I downloaded 'aycn28ww.exe' from the S145-15AST Lenovo support page and have copied two ranges of bytes from original to new that I believe to be the DMI, 2A3000h-2A321Fh and 2A4000h-2A423Fh. No idea if I need both, I searched for ASCII 'LENV' and found two matches, the data between each range is just FF.
                      I have attached the extracted BIOS in case it is important. Please can someone advise if I am doing this correctly? If not, can a patched BIOS be provided?
                      Thanks.
                      • lapfix
                        • Mar 2020
                        • 2733
                        • my workshop
                        #51
                        Yes you do right
                        the data between the 2 " lenv" is crypted and yes try your new build bios
                        • mANgLEr
                          • Feb 2023
                          • 12
                          • England
                          #52
                          Unfortunately, the laptop is still not working. As before the power light comes on solid. This time, however, after about 30 seconds the heatsink fan starts and it didn't do that before re-flashing the BIOS. I will try to find an unused HDMI cable in my piles of cables so I can try the external output.
                          A thermal camera does not highlight anything that looks wrong either. I've probed all over the board and cannot find anything that seems wrong, but I don't yet have the schematics. Will go and request that now.
                          • jimore
                            • Nov 2020
                            • 177
                            • mexico
                            #53
                            please help me
                            led blinking
                            • Macias
                              • Nov 2019
                              • 83
                              • Ecuador
                              #54
                              this is working. Problem ok.
                              it worked very well thanks
                              • SAHILSHAIK
                                • Jul 2024
                                • 27
                                • india
                                #55
                                LENOVO IDEAPAD S145-15AST FS44A FS54A NM-C171 REV 1.0
                                TESTED BIOS
                                • foneRoc
                                  • May 2022
                                  • 8
                                  • Jamaica, W.I
                                  #56
                                  Lenovo IdeaPad s145-15ast
                                  S/N PF1SBXFF
                                  Board # FS44A&FS542A NM-C171 REV 1.0
                                  AMD A6
                                  Hello to all. The system boots up to Black Screen even on external Monitor...
                                  Charging and power Leds are present. Fan kicks in once cpu come to tempreture..
                                  I use EZP2023 To read bios chip then save two copies each being the exact size of 8,192kb. I am not sure if this size is the correct data that should be on said chip as I am DIY newbie when it comes to the Bios..
                                  Thanks in advance for any Help!!
                                  • shiyab
                                    • Sep 2023
                                    • 1495
                                    • india
                                    #57
                                    S/N PF1SBXFF
                                    AMD A6
                                    hi try not dmi
                                      • 21002
                                      S/N PF1SBXFF
                                      AMD A6
                                      Bios + DMI .
                                      • foneRoc
                                        • May 2022
                                        • 8
                                        • Jamaica, W.I
                                        #59
                                        Thank you Shiyab for your Help I will try and update you...
                                        • foneRoc
                                          • May 2022
                                          • 8
                                          • Jamaica, W.I
                                          #60
                                          Thank you SMDFlea for your help aswel.. However the system still does not give a display local or external.. Charging Led lit and when press power botton we get power LED as before.. Im not sure as to what to do next.. Any suggestions? Really cam use it TIa Forgive my late response..
                                            Lenovo 3000 Series Schematic
                                            Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                            3000 C100 laptop with Braille keyboard
                                            Lenovo 3000 C
                                            C100, C200 - 15-inch XGA screen
                                            Lenovo 3000 N
                                            N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                            N500 - 15.4 inch screen.
                                            Lenovo 3000 V
                                            V100, V200 - 12.1-inch WXGA models
                                            Lenovo 3000 G
                                            G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                            10-04-2024, 06:05 AM
                                            Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                            09-06-2024, 06:40 AM
                                            This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                            09-06-2024, 06:06 AM
                                          • derradji89
                                            Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                            by derradji89
                                            Hi everyone 🤗
                                            I have a Lenovo MIX 320-10lCR computer.**
                                            1. **Operating System**: Windows 10 ** Education** 64-bit.
                                            2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                            3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                            4. **BIOS Chip Reflashing**: Currently,...
                                            04-19-2025, 03:04 PM
                                            LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                            This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                            09-12-2024, 02:30 PM
