Dell Latitude 5410 Bios Password 8FC8
HI DELL 5410 FDZ41 LA-J371P REV 1.0 BIOS UNLOCK
Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Bios Clear Password & clean meAttached Filesif you find these attachements useful please consider making a small donation to the site
Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
Type the laptop service tag, motherboard model, etc.
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
Read the bios guides, you will find info about removing dell passwords ,and there is also an ME firmware cleaning guide.
BIOS guides, methods, resources and tools
https://www.badcaps.net/forum/troubl...rces-and-toolsComment
latitude 5410
la-j371p rev 1.0
sn J4M5Y33
I need to clean it. booting takes a long time thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
hi tryAttached Filesif you find these attachements useful please consider making a small donation to the site
THANKYOU. WORKING BIOS 100%.
TESTED ON DEAD LAPTOP.
FAULT.... PRESSING POWER BUTTON LED LIGHT WAS SHOWING ORANGE ONLY.
PROGRAMED THIS BIOS. NOW DISPLAY OKK. BUT 30 SECONDS LATE DISPLAY. I TRIED TO CLEAN ME REGION BUT TOOL SHOWING ERRORComment
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
- Name your thread with make, full model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
3.4. Dell
Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
Note: There is no publicly available 8FC8 generator available at the moment.
The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher​↵
​https://www.badcaps.net/donateComment
Hello. Can someone unlock this bios password please
ST: H3C5593
EX:37207093719
Motherboard: FDZ41 LA-J371P
Rev 1.0 (A00)
2020-03-10Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi, is it possible to get a clean .bin BIOS file for dell latitude 5410 somewhere?
Or do I need to send mine so someone can remove the password?
Thanks in advance
you can use the Dell 8FC8 Patcher to patch your own bios file then reflash it...
Thanks for the quick reply
Just so I understand correctly,
this patcher works by finding the hex values which contain the password in my extracted BIOS file and erasing them, right?
and then I can use the BIOS file without the password to flash the chip and it should work?
Thanks!Comment
by Godfather79Hello everyone in the community
Dear Sir,
I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
Problem details:
* Model: Dell Latitude 5520.
* Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
* Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
* Service Tag: (Enter your actual Service Tag from the laptop here)
* ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....-
Channel: BIOS Requests ONLY!
by lzetaI have a dell 5410 with locked bios, than I dump bios from a identical laptop and I've flashed it. But now all system information are identical to the bios donator laptop, how can I write again the correct service tag and other infos? I attach the original loched bios bios, how can I extract the right infos? And how can I write it?...
by gugutmhi everyone,
need some advice i am not professional just junior , but maybe someone could help me please
i have
Device : Laptop
Brand : DELL
Model : LATITUDE 5410
Board Number: FDZ41 LA-J371P Rev:1.0
i am attaching schematics and board view. [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...14#post3484414
my problem is its not turning... -
by skinnerLooking for some help with a bios password. Any help would be appreciated.
Dell Latitude 9410
Service Tag - H803043
Board - LA-J541P REV 1.0...-
by x44nHello,
my dell is stuck on the Dell Security Manager
Can someone please delete this password from bios?
Thank you a lot....-
- Loading...
