help me with a bios dump for Acer Swift 3 SF313-52
  • bisscableguy
    • Jun 2016
    • Romania
    Hello! Can you help me with a bios dump for Acer Swift 3 SF313-52-55C1?
    Thank you!
    • 22097
    Re: help me with a bios dump for Acer Swift 3 SF313-52-55C1
    Post your bios backup .
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      Originally posted by smdflea
      post your bios backup .
      board :nb8511_pcb_mb_v5
      snid: 034043808223
      sf313-52-52qp
      2020/08/24
      bios and ec bin attached
      • rediii
        h???, spurrrn
        • Mar 2018
        • 501
        • somewhere in europe
        Thank you!
        try...
        • kalilinux25
          • Mar 2018
          • 2093
          • ZAMBOANGA SIBUGAY
          snid: 034043808223
          sf313-52-52qp
          2020/08/24
          Hope somoene can help me
          • kalilinux25
            • Mar 2018
            • 2093
            • ZAMBOANGA SIBUGAY
            When I try to run the software I get this error?
            Im trying ti extract the bin file but getting this error?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12413
              It's here
              ​https://www.badcaps.net/donate
              • kalilinux25
                • Mar 2018
                • 2093
                • ZAMBOANGA SIBUGAY
                Originally posted by hoaca388
                It's here
                Thanks how can you split those file into bios and ec bin?
                  • 22097
                  With a hex editor
                  • kalilinux25
                    • Mar 2018
                    • 2093
                    • ZAMBOANGA SIBUGAY
                    Originally posted by SMDFlea
                    With a hex editor
                    How do I cut form the top of the new bin to the last? do I need to know what is the excat offset? and hw do I know? I already found where is the first and the last of the new bios bin in the hexeditor. but I cant cut it if I do it manually
                    • kalilinux25
                      • Mar 2018
                      • 2093
                      • ZAMBOANGA SIBUGAY
                      With a hex editor
                      please check sir, im very haappy that im learning now
                        • 22097
                        Search for the word BIOSIMG, the bios starts on the line below so put your cursor there and that will set your first offset, select the block and set the length as 1000000 (1 million in hex is 16MB) .Copy and make a new file,paste into the new file and save. Then copy the DMI from your backup using the offsets 6CD000 - 6D803F and paste-insert into the virgin bios using the same offsets
                        • kalilinux25
                          • Mar 2018
                          • 2093
                          • ZAMBOANGA SIBUGAY
                          With a hex editor
                          also the ec sir
                            • 22097
                            the bios is good
                            also the ec sir
                            no,its not good.The ec is copied from the bios to a new file (20,000 is 128KB)
                            • kalilinux25
                              • Mar 2018
                              • 2093
                              • ZAMBOANGA SIBUGAY
                              the bios is good
                              how can you determine the starting and the end of ec? when I compare my backup ec they dont have the same starting and end text..
                                • 22097
                                Your EC backup you posted isn`t the EC, its frimware for the DP or USB-C ,or something . The EC chip is the ITExxxx .
                                • kalilinux25
                                  • Mar 2018
                                  • 2093
                                  • ZAMBOANGA SIBUGAY
                                  ahw, i thought it was the ec in the first place .. But how can I tell that the starting of the ec bin?
                                  • kalilinux25
                                    • Mar 2018
                                    • 2093
                                    • ZAMBOANGA SIBUGAY
                                    the bios is good
                                    so my new bios is good? Can I flash it ?
                                      • 22097
                                      Yes,but if you want the DMI as well copy that into it first,i gave you the offsets at post #12 6CD000 - 6D803F
                                      • kalilinux25
                                        • Mar 2018
                                        • 2093
                                        • ZAMBOANGA SIBUGAY
                                        hope I got it right sir
