Lenova G50-70 NM-A271 uma enable
  • Öğretmen27
    • Oct 2019
    • 36
    • TÜRKİYE
    Hello there. I want to do the computer I mentioned in the title. Could you help?
    Is there a need for bios after Uma?
  • imranromi
    • Jan 2015
    • 1292
    • Pakistan
    Re: Lenova G50-70 NM-A271 uma enable
    Not tested..
    • Öğretmen27
      • Oct 2019
      • 36
      • TÜRKİYE
      Thanks for the answer. Have you ever done it? Is it happening? Do you need bios after doing this?
      • amirarbabi
        • Feb 2019
        • 37
        • usa
        thank you for help
        • sheffieldyorky
          ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
          by sheffieldyorky
          Hey there people
          While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
          This is what I tried, but not in any order.
          Google
          YouTube
          BIOS
          Command Prompt (administrator privileges)
          On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
          10-25-2025, 02:22 AM
        • BC_TechForum_drb
          Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
          by BC_TechForum_drb
          Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
          Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
          Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
          2/ Figure 1 Gfx-D500-B Front Facing
          3/ Figure 2 +5v supply (zoom-in)
          Intro:
          While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
          12-07-2023, 09:55 PM
        • questore
          Looking for a DC-DC step down converter module to replace a 0.75v_ALW output and enable pin
          by questore
          Hello Everyone,
          I need your help, maybe you have know where to buy a replacement.
          I have a NM-D562 laptop motherboard that has a burned 0.75_ALW converter. (the layers and the pins also burned so i dont want to restore it but i need a replacement)
          I have checked with lab power supply output (0.77V) laptop works, so i need a DC-DC module that can do its job.
          According to schematic datasheet what i need on 0.75V_ALW:
          Vout=0.75V±37.5mV
          Vset=0.752V±1.46%
          Vref=0.6V
          TDC=4A
          OCP=9.5A TYP=10.5A MAX
          OVP=(1.15~1.25)*Vout
          UVP=(0.6~0.7)*Vout​...
          11-10-2025, 03:36 AM
        • platinumsteel
          HP 14-dq2088wm 11th Gen Missing 3V/5V Standby Voltage
          by platinumsteel
          Hi guys have a HP 14 Labtop. DA0PAHMB8F0 .There is no White LED on the DC Jack .It got a drop of water damage right next to the 3V IC ( Silergy SY8386BRHC) and corroded a resistor and a pad which belongs to the Enable for the IC. I cleaned the area and re-soldered the resistor. Nothing Changed. I don't know what the value for the resistor should be.It measures about 80.0K No schematics available for this model. A good friend on here mon2 helped me identify the IC markings and gave good advice on making sure to measure the input voltages and enables and checking for short.
          There is no short...
          11-12-2024, 05:49 AM
        • jacky.xue
          Do anyone know my lenova current condition now ?
          by jacky.xue
          Hi everyoneone:
          My lenova note book after power button press, it blink 12 times in white led, check attached video ~
          have anybody see this condition?
          Before i try flash bios 8M&16MB , it ok, but maybe i didn't backup (read) these flash raw data,
          after i write backup 8&16 MB image to laptop again ~ it become this conditions now ,
          I don't know if 8M or 16M image is incorrect ~ could somebody have this kind of condition can give me some idea ?
          I am sorry, my english is not well ...
          Might be write corrupt bios back to note book....
          07-18-2025, 04:43 PM
