CCE UltraThin S23 / Bangho Zero 1309 + 1310 - Mobo: TU131 NPB Ver:D
  • PinGuy
    • Oct 2016
    • 74
    • Argentina
    All voltages fine, Main-PWROK signal goes high. If the board has no RAM, power turns on and stays on, but if a working RAM is in the socket, it cycles on and off constantly, with no picture on screen at all. CMOS battery is OK.
    Could this symptom be a bad BIOS? Can somebody help with a BIOS dump to try?
    I know this might be hard because this is a Brazil / Argentina model, but maybe one of the gurus around here has it. A schematic does not even exist for this
    Thanks in advance!
  • peste
    • Dec 2016
    • 12852
    • ROMANIA
    Re: CCE UltraThin S23 / Bangho Zero 1309 + 1310 - Mobo: TU131 NPB Ver
    post the original bios
      • 20966
      Post any other motherboard part numbers too,similar to 6-71-W8400-D03 .Its a clevo board i think .
      EDIT: it isn`t a clevo, the board is made by Topstar.
      Try this bios
      • PinGuy
        • Oct 2016
        • 74
        • Argentina
        I'll will try those! Thanks SMDFlea!
        BTW I dumped the original BIOS (attached, don't know if it is OK or not), and I'm also attaching pics of the mobo.
        • PinGuy
          • Oct 2016
          • 74
          • Argentina
          Ok, was about to burn the BIOS but I notice the file is 4MB and the original is 8MB, should I write it as is, or should I copy it over twice to fit the 8MB chip?
            • 20966
            No don`t write it twice. There are 4MB and 8MB dumps for the TU131 board,the 4MB one is the only one i found for free.
            Try this bios
            • PinGuy
              • Oct 2016
              • 74
              • Argentina
              Oh I see, thanks for the cleaning. Anyway, I guess the dumps I got are OK, as after more diagnosing I found that VGFX is actually missing, and even without that voltage Main-PWROK goes high, so this signal is not monitoring all voltages actually as I thought.
              Now I need to find why it is missing, on pg 43 of the schematic I see it is coming out of the ISL95837 power driver IC, which also handles VCORE. But VCORE is fine, so I don't know if this chip may be the culprit and be "partially" dead.
              • PinGuy
                • Oct 2016
                • 74
                • Argentina
                Ok, goes to trash. uP's gfx is shorted
                A very crappy board this is.
                • wal1331
                  • Sep 2021
                  • argentina
                  Hi guys I need U731 MB NPB VER D Bios, I have tried the versions of this post and it did not work. I would appreciate the help.
                  • yamish23
                    • Jul 2019
                    • 8
                    • philippines
                    what is the part number of this IC? thanks
                      • 20966
                      schematic https://www.badcaps.net/forum/showth...ighlight=TU131
                      • yamish23
                        • Jul 2019
                        • 8
                        • philippines
                        Originally posted by SMDFlea
                        thanks bro.
                        • yamish23
                          • Jul 2019
                          • 8
                          • philippines
                          your schematic is rev A and mine is rev D. are they the same?
                            • 20966
                            no,but it might be close enough to help you.
                            • yamish23
                              • Jul 2019
                              • 8
                              • philippines
                              OKAY BRO.
                              • Ola_ke_ase
                                • Sep 2021
                                • Argentina
                                hola amigo pudiste conseguir el bios? yo tambiƩn necesito
                                Hello friend, were you able to get the bios? I need too
                                • Blackam8899
                                  Bangho Cloud g pro Bios
                                  by Blackam8899
                                  Hello group, I am looking for the bios of the Bangho Cloud g pro device Bios with mother number Y116A REV 1.2, the device fails, it turns on and off sometimes it turns on, the voltages in the device are stable, we repair the first stage mosfet and change charger (we changed 3 times thinking this was the fault but it has been ruled out) I await any help!
                                  Or if someone can clean the ME region it also helps me to try!...
                                  12-04-2023, 01:44 PM
                                • Blackam8899
                                  clevo 6-71-w8400-d03 / Bangho Zero 1430 binaries!
                                  by Blackam8899
                                  Hello friends, I am needing the clevo 6-71-w8400-d03 binaries, they are 4mb and 2mb files. The device turns on with all its voltages and consumption of 350ma but it does not give an image and the consumption remains static. The bios signals are very short so I suspect that the problem lies there, (to complete the problem I accidentally deleted the 2mb bios so I'm in trouble! I appreciate any contribution in advance!
                                  09-13-2023, 05:00 PM
                                • el panke
                                  Bangho bes-1308
                                  by el panke
                                  im looking for help with this one, its locket with password and couldn't find another file for this motherboard
                                  mother model 6-71-w13e0-d02 (w130exmb-0D)
                                  thanx in advance...
                                  10-29-2021, 03:32 PM
                                • PinGuy
                                  TOPSTAR TU131 REV. A Schematic
                                  by PinGuy
                                  Oh my! I looked everywhere for the schematic without success. But "Topstar" was the keyword! Thanks again SMDFlea!!! ...
                                  09-15-2020, 12:42 PM
                                • francocariman
                                  6-77-w550su10-d03a need bios
                                  by francocariman
                                  Hi, the laptop is bangho max g01
                                  Please if anyone can help me with the BIN & EC files please
                                  thank...
                                  06-25-2025, 10:20 AM
