Microsoft Surface Pro 7 NEED BIOS. HELP!
    Re: Microsoft Surface Pro 7 NEED BIOS. HELP!
    Originally posted by tccyo22 View Post
    Just realised the compressed file only contained my cleaned BIOS. I've reattached with both the original dump and cleaned version.
    And with an update to this, a new board and lcd assembly and still no touch with a cleaned ME, checked in the no touch thread about the sensor hub but it hasn't helped me. This is where it's new to me if the touch firmware portion of the BIOS is broken. I've tried once more to update with the microsoft firmwares but no luck. The UEFI is reporting touch firmware 3.1.75.139.
    If anyone can point me in a direction where to go next I would really appreciate it. Or if anyone can take my BIOS and try it on their SP7 to see if they can get touch to work.
    Hello. Вid you manage to solve this problem? I have exactly the same problem. Thanks
      Good afternoon from Ukraine. Need help from a specialist to revive Microsoft Surface Pro 7 1866. The logo appears for 3 seconds and goes out. I am attaching the original bios. I will be grateful for your help.
        So my surface pro 7 boot looped for a couple of boots but it hasn't booted or boot looped for weeks now, just windows logo for a second or two, sometimes it shows the logo for longer, until it flashes off and on again like its going to boot, but only very rarely and it never boots, tried running it flat, didn't work, is there a solution for this yet?
          Can someone help me get the logo to turn off on Surface Pro 7 1960? This is the bios, please help me. TK
            You can try the me cleaned working bios that I posted few posts back. However the 3 second logo loop might be caused by multiple hardware faults as well. In my experience anything that goes wrong in the power up sequence can cause this (short on any rail, etc.). Did you check all the rails for shorts?
              Surface with password
              pls can anyone unlocked bios
                Serial number - https://www.badcaps.net/forum/showthread.php?t=103570
                  Sorry mr smdflea
                  surface pro 7 1866 256 GB s/031338304153
                  I ALREADY TESTED SOME DUMP WITH SESULT LOGO MICROSOFT APPEAR A FEW SEC AND TURN OFF
                  THANKS
                    Surface Pro 7 Plus Bios Uefi Lock
                    Hi. Uefi password required. Anyone can help me ?
                      Re: Surface Pro 7 Plus Bios Uefi Lock
                      Serial number required - https://www.badcaps.net/forum/showthread.php?t=103570
                        Originally posted by smdflea View Post
                        SURFACE PRO 7 PLUS 256gb *Model 1960
                        thx!
                        sn/ 004228513353
                          SURFACE PRO 7 PLUS *Model 1960
                          thx!
                          try
                          all donations are welcome,
                            Originally posted by volinakis View Post
                            try
                            it's working, thxxx!!!!
                              Cu placere! (you are welcome)
                                please unlock my surface pro 7 password
                                surface pro 7
                                serial number : 033666403353
                                  surface pro 7
                                  here. Thanks go to Vesko356.
                                    thanks volinakis to you and Vesko356
                                      I have bought a second hand Surface Pro 7 Plus (256 Gb, model 1960), and the uefi is password protected.
                                      My question may be stupid: can I just flash the bios made by volinakis (#192), or does it need to be edited to match my serial number.
                                      My SP7+ also allows boot from usb drive.
                                      My sn: 006733213653
                                      Thanks in advance !
                                        My sn: 006733213653
                                        Thanks in advance !
                                        you have to read your bios chipset and post it here. 99,9% sure it won't start with bios from another surface.
                                          A 0.1% chance of success is all the motivation some of our members in this forum need if its the easy route
