Hi. Uefi password required. Anyone can help me ?
Surface Pro 7 Plus Bios Uefi Lock
by FalconPunchHello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...-
Channel: BIOS Requests ONLY!
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
Symptoms:- Laptop powers on but no display at all (completely black screen)
- Caps Lock blinks twice with a pause, then repeats continuously
- F12 LED stays on permanently
- No POST, no boot sequence, nothing on screen
Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
What I've tried:- Hardware reset (battery removal, power
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by ArtMovHi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
1. I made overclocking lock disabled the default in amibcp
2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...-
03-31-2023, 01:30 PM -
- Loading...
